Introduction: How to Make Beaded Flower Earrings With Blue and White Imitation Jade Beads
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Love this pair of beaded flower earrings? This article will show you how to make such style of beaded drop earrings in details.
Step 1: Supplies Needed to Make These Beaded Flower Earrings:
8x6mm DarkBlue Electroplate Glass Beads
8x6mm CornflowerBlue Imitation Jade Glass Beads
6mm White Imitation Jade Beads
Silver Earring Hooks
1mm Copper Jewelry Wire
Aluminum Wire
0.3mm Copper Jewelry Wire
Needle Nose Pliers
Round Nose Pliers
Diagonal Pliers
Step 2: Make the Basic Part of These Beaded Dangle Earrings
1st, cut a piece of 2mm aluminum wire and make a hoop for it like picture shows;
2nd, cut a piece of long enough 0.3mm copper jewelry wire and wrap it around the hoop as picture shows.
Step 3: Make the First and Second Layers for the Beaded Flower Earrings
1st, slide one 8x6mm dark blue electroplate glass bead to the wire and wrap it around the hoop like picture shows;
2nd, repeat the same ways to another nine dark blue glass beads to the hoop as picture shows;
3rd, continue to slide a 8x6mm cornflower blue imitation jade glass bead to the wire in the middle part of the two dark blue beads as picture shows;
4th, repeat the same ways to add another seven cornflower blue glass beads to the wire like picture shows.
Step 4: Make the Third and Fourth Layers for the Beaded Drop Earrings
1st, cut a piece of 1mm copper jewelry wire, then slide three 4mm light blue imitation jade bead to the left end of the wire, next slide another three 4mm light blue imitation jade beads to the right end of the wire, finally cross the two ends to form a flower pattern like picture shows;
2nd, slide one 6mm white imitation jade bead to the wire and put it in the center of the prepared flower pattern as picture shows.
Step 5: Finish This Beaded Flower Pattern
1st, fix these wires and cut off the rest parts like picture shows;
2nd, cut off a piece of 2mm aluminum wire, then connect it with the flower pattern.
Step 6: Complete This Pair of Beaded Flower Earrings
1st, slide one dark blue glass bead, one light blue glass bead, then one dark blue glass bead and one light blue glass bead in sequence to the wire and make a hook of it as picture shows;
2nd, attach a earring hook to the beaded pattern like picture shows;
3rd, repeat the same ways to make another one of these beaded drop earrings.
Step 7: ​This Pair of Glass Bead Earrings Are Ready! Let's Check It's Final Look.
Do you love this pair of beaded flower earrings? I really like them, which are so chic and eye-catching. Especially in this winter, dark blue is a good color to match clothes. If you are interested in such type of beaded dangle earrings, just follow this simple earring tutorial to have a nice try. Welcome to share your designs with me, have a good time!
