How to Make Bloody Mary Pickles
49,470
62
19
Introduction: How to Make Bloody Mary Pickles
While attending a recent family reunion, My husband fell in love with a store-bought "spicy bloody Mary pickle". Since I could not find them on store shelves in my small home town, there was only one answer....you must can your own! So I did.... and after a couple of salty failures, I think I have a tasty product, but more importantly, I have pleased my hard-working hubby with a delicious snack!
Step 1: From the Garden You Will Need:
Lots of rain in Missouri = Lots of garden goodies! We will use the cucumbers, dill and garlic from this bounty!
1. pickling cucumbers
2. dill
3. garlic
Step 2: From the Pantry You Will Need:
1. your favorite store-bought bloody Mary mixer (or use your own if you can your own!)
2. white vinegar
3. canning salt
4. whole peppercorns
5. crush red pepper flakes
Step 3: Prepare Your Jars
1. in a large canning pot with rack, place clean jars and lids in boiling water to sterilize, making sure water covers your jars. I used pints for this batch and I was able to get about 7 and 1/2 pints from my cucumbers. To save time always have a few extra jars ready and a smaller jar for any that might not fit in the size you are canning. Small jars make a nice addition to your lunch box!
Step 4: Clean and Prep Cucumbers
Put cucumbers in a clean sink of water and wash gently with brush. Remove all dirt, debris, spots, stems and dry by laying out on clean paper towels. I don't cut any cucumbers at this point. I wait until I am putting the cucumbers in jars, this allows me to "design" them for a nicer fit.
Step 5: Brine Time
In a large heavy stock pot, combine 1.5 quart of bloody Mary mixer with 1 pint white vinegar.
Stirring occasionally, bring to a easy boil, reduce heat and simmer for 5 minutes, turn off and cover with lid to keep warm.
Step 6: Peel and Slice Garlic
Peel and slice garlic. you will use about a teaspoon of sliced garlic per pint
Tip:Garlic should always be stored in a cool dry dark place. I ran across a great idea on the internet several years ago and I LOVE it. Store you garlic in a clean nylon hose, knotted after each garlic bulb is inserted. hang in a cool, dry place in your kitchen. As you need garlic, simply cut off the nylon just under the knot!
Tip:An easy way to peel garlic, is using a silicone garlic peeler. If you don't have one, try any thin silicone mat or silicone trivet you have on hand. Simply roll your garlic clove in it, while firmly pressing down and the peels come right off!
Step 7: Pack the Pickles
Using jar lifters or tongs, remove one jar at a time from the sterilization canner. Place one teaspoon of garlic slices and one nice young sprig of dill in jar. Pack cucumbers in as tight as you can without bruising or forcing the vegetable.
Tip: Roll your jar on its side as you begin to fill, this will allow you to pack a few more of those beauties into the bottom of the jar, then you can stand it up and work your puzzle magic! With a little effort you can have a beautiful jar of pickles that look like they were grown just to be a family in that jar!
Tip: I like small whole pickles, they have the best "crunch", but if you want more flavor and a little less crunch you can half or spear. The best trick to a crisp / crunchy pickle is pick and pickle quick! Picking your cucumber and pickling soon will result in the best pickle. If you are buying your pickles at a market, always check for fresh firm cukes, and pickle as soon as you can. Soak in ice water if you don't plan to pickle on the first day you purchase..GOOD LUCK!!
Step 8: Add the Bloody Mary Brine
Add enough brine to the packed cucumbers, leaving 1/2 inch headspace. Add 1/2 teaspoon of canning salt, 1/2 teaspoon of peppercorns and 1/2 teaspoon of crushed red pepper to each pint jar. Wipe jar tops with moist paper towel, making sure the rims and tops are clear. Add lids and bands, finger tighten and place in the hot water bath canning rack.
Tip: As long as your water from sterilizing the jars is clean and clear; use it to hot water bath your pickles. I usually add a splash of vinegar to my canner water to prevent any clouding that might accumulate on the outside of the jars from chemicals in my water. It also makes clean up much easier!
Step 9: Hot Water Bath
Place jars on rack in canner and submerge into the water. Water should cover your jars. Bring to a boil and let boil for 15 minutes. Remove from canner, cool and wait for the magical "pop" !
These pickles are best if left to rest for 6 weeks! No need to refrigerate until you open!
Step 10: Keep Enjoying ...even After the Pickles Are Gone!?!
If you are a pickle loving, bloody Mary lover.....add a stick of celery, and an olive or two, and a shot or so... of vodka to the brine = one more way to love this home canned goodness!
Canning and Pickling Contest 2016
Be the First to Share
    • Halloween Contest
      Halloween Contest
    • Robots Contest
      Robots Contest
    • 3D Printed Student Design Challenge
    19 Comments
    Chefman007
    Chefman007
    Question 2 years ago on Step 2
    I need to make 12 Quarts of this Recipe
    What do I do to make a larger batch ?
    Thank You
    TerriJ20
    TerriJ20
    Answer 2 years ago
    You would multiply the recipe by approximately 3.5, so 5 quarts of bloody mary mix, 3.5 pints of vinegar, and dill, garlic and 1 teaspoon of each: peppercorn, canning salt and crushed red pepper. I will tell you that I have not made a batch this large, I always small batch can these! Good luck!
    cgaddy18
    cgaddy18
    Question 3 years ago on Step 10
    I don't have access to fresh dill, can dill seed be used in it's place? Also can this be made in quarts and still be safely canned?
    TerriJ20
    TerriJ20
    Answer 3 years ago
    Yes you can use the seed, I just prefer the fresh. Check you local store's produce section, you can sometimes find it in the "stay fresh" small plastic container hanging near fresh herbs. I have not canned in quarts, simply because I hated to HWB any longer than 15 minutes. I would say it would be ok to increase the HWB to 20 minutes, but I wouldn't go past that! You may risk the crispiness of the pickle. Hope this helps!
    sarazan
    sarazan
    4 years ago
    I have just a quick question. Are the measurements for spices for a quart jar or a pint jar? Thanks.
    JudyB55
    JudyB55
    Reply 4 years ago
    The recipe says pints.
    SaraZ6
    SaraZ6
    Reply 4 years ago
    Thank you! I guess I didn't see that!!
    BrandiW14
    BrandiW14
    5 years ago
    These were amazing!! Taste was great and had just enough of a kick!
    TerriJ20
    TerriJ20
    Reply 5 years ago
    Glad you enjoyed them Brandi, and I appreciate your comment here!
    MaryT8M
    MaryT8M
    5 years ago
    I made these today.....now the waiting begins! I added the leafy tops of celery to my jars. My Mom used to do that when ever she wanted more of a "celery" taste. She added them to soups and when canning tomatoes. Nice recipe!
    TerriJ20
    TerriJ20
    Reply 5 years ago
    I hope you enjoy!!
    xxlauraxx
    xxlauraxx
    5 years ago
    Yum, these sound amazing! I love the beautiful photo of your garden bounty, too.
    Hey, you should make an Instructable for your garlic storage technique. I've never heard of that before, and it seems like a really good idea!
    TerriJ20
    TerriJ20
    Reply 5 years ago
    Thanks!
    I think I will take your advice....maybe my next instructable will be my garlic storage!
    MaryT8M
    MaryT8M
    5 years ago
    OMG this sounds SO good.....why hadn't I ever thought of it??? My daughter ALWAYS orders her Bloody Marys "spicy and with a dill pickle" instead of the olive! I will be trying these VERY soon! Thanks
    TerriJ20
    TerriJ20
    Reply 5 years ago
    So glad you plan to try, let me know how you like! We are happy with the results!
    becca327
    becca327
    5 years ago
    Mmmmm...can't wait to try them! I have a pickle lover in my family and I think this will be just the thing to make their day. Just wondering, if I want to add celery, do I add that in with the pickles before the hot water bath? Thanks for sharing. :-)
    TerriJ20
    TerriJ20
    Reply 5 years ago
    Thats what I plan to do. When I make "end of the garden pickle mix" I put celery in, and I love the taste, so I think it would be similar. Which makes me think now.....I make try some "bloody Mary end of the garden pickle mix"! Thanks for giving me another inspiration!
    wold630
    wold630
    5 years ago
    These sound so good!
    TerriJ20
    TerriJ20
    Reply 5 years ago
    We really like them! The next batch I make I am going to put a few pieces of celery in too!
