Introduction: How to Make Colorful Butterfly Friendship Bracelet With Acrylic Beads for Girls
Are you colorful bracelet lover? If yes, today’s Pandahall tutorial on how to make colorful butterfly friendship bracelet with acrylic beads for girls is a fabulous choice for you!
Step 1: Materials Needed for the Butterfly Friendship Bracelet:
Step 2: Make the Base of the Butterfly Friendship Bracelet for Girls
1st, cut off a red piece of nylon thread and make two knot and use two yellow iron pins to fix them;
2nd, trim off a piece of pink nylon thread and braid it around the red nylon thread twice and tighten it;
3rd, continue to braid the light blue and orange nylon threads on the red one along the pink nylon thread.
Step 3: Braid the Nylon Threads
1st, braid the lower light blue nylon thread twice on around the lower pink one, then continue braid the orange and red nylon thread around the lower pink one;
2nd, add the iron pin in the center to fix the nylon threads;
3rd, continue to braid the orange, red and pink nylon threads around the light blue one.
Step 4: Continue to Braid the Nylon Threads
1st, braid the red, pink and light blue nylon threads around the orange one and make them tight;
2nd, repeat braiding the nylon threads three times.
Step 5: Finish the Fist Angle
1st, braid the red, orange and light blue nylon threads around the pink one and make them tight;
2nd, continue to braid the nylon threads five times from right to left.
Step 6: Start to Make the Second Angle
1st, fix the nylon threads with an iron yellow pin, then braid the pink, light blue and orange nylon threads around the red one;
2nd, repeat braiding the nylon threads two times from left to right;
3rd, fix the nylon threads with an iron pin and braid the pink, red and orange nylon threads around the light blue one;
4th, repeat braiding the nylon threads three time from right to left;
5th, braid the light blue nylon thread around the orange one.
Step 7: Continue to Braid the Nylon Threads
1st, braid the pink nylon thread around light blue and orange ones and tighten them;
2nd, braid the red nylon thread around the orange and pink ones and make them tight.
Step 8: Continue to Make Other Two Angles
Repeat the same ways mentioned above to make other two angles.
Step 9: Finish the Outline of the Butterfly Friendship Bracelet
1st, after the four angles finished, thread the light blue nylon thread on the left side and the pink nylon thread on the right side through the circle in the center;
2nd, tighten the four nylon threads and we get the outline of the nylon threads butterfly.
Step 10: Make the Antlers of the Nylon Threads Butterfly
1st, fix the butter fly with three iron pins, then braid the two pieces of red nylon threads around the pink and light blue nylon threads;
2nd, continue to braid the red nylon threads around the pink and light blue ones several times until it’s full, then cross it through the orange nylon thread;
3rd, make a knot on the red thread respectively and slide a pink acrylic beads on both red nylon threads separately, then cut off the make a knot and cut off the excess red nylon threads.
Step 11: Finish the Braided Butterfly Bracelet
1st, cut off two pieces of light blue nylon threads and hang it on the right and left side of the butterfly;
2nd, continue to trim off two pieces of light blue nylon threads and braid it around the right and left side nylon thread on the butterfly separately;
3rd, combine the right and left side nylon threads together and continue braid an orange piece of nylon thread around them, then trim off the excess orange threads;
4th, make a knot at the end of the light blue threads separately.
Step 12: Time for the Final Look of the Nylon Threads Butterfly Friendship Bracelet:
Wow, what a stunning butterfly friendship bracelet! Do you love it? Maybe it’s a little complicate, but i believe it’s worthy of your time and energy! If you are planning to make the bracelet but have some confusion, please feel free to ask me or leave a comment. Hope you a nice try and enjoy yourself~
