Introduction: How to Make Continuity Tester Using BC547 Transistor
Hii friend,
Today I am going to make a circuit of continuity tester.Using this circuit we can test continuity of many components like as Diode, LED etc.This circuit I will make using BC547 transistor.
Let's get started,
Step 1: Take All Components As Shown Below
Components required -
(1.) Transistor - BC547 x1
(2.) LED - 3V x1
(3.) Resistor - 220 ohm x2
(4.) Resistor - 10K x1
(5.) Buzzer x1
(6.) Battery clipper (Remove from old battery) x1
(7.) Battery - 9V x1
(8.) Probes (+ve probe and -ve probe)
Step 2: Transistor BC547
Pins of BC547 transistor
Step 3: Solder Transistor
Solder emmiter pin of transistor to +ve pin of battery clipper as shown in the picture.
Step 4: Connect 10K Resistor
Next we have to solder 10K resistor between Base pin and emmiter pin of the transistor as you can see in the picture.
Step 5: Solder 220 Ohm Resistor
Solder 220 ohm resistor to base pin of the transistor as solder in the picture.
Step 6: Connect Buzzer to the Circuit
Solder +ve pin of buzzer to -ve of battery clipper and
Solder -ve pin of buzzer to collector pin of the transistor as solder in the picture.
Step 7: Connect 220 Ohm Resistor
Solder 220 ohm resistor to +ve leg of LED.
Step 8: Connect LED to the Circuit
Next we have to solder LED to the circuit.
Solder +ve leg of LED to -ve of battery clipper and
-ve leg of LED to collector pin of transistor as you can see in the picture.
Step 9: Connect Wires of Probe
Now Solder +ve probe to -ve of battery clipper and
Solder -ve probe to 220 ohm resistor which is solder in the base of transistor as you can see in the picture.
Step 10: How Can We Use
Now our circuit is ready so Connect battery to the battery clipper and use this circuit for continuity test.
As we can test Diodes,Wires,LEDs etc.
If you want to make more electronic projects like this then follow utsource now.
Thank you
