Introduction: How to Make DIY Home Decor Lantern Very Easily
In this project, we are going to make DIY Home Decor Lantern very easily at home for Diwali/Festive Decorations. This lampshade made from paper is simple to make but looks spectacular.
  1. Cardboard
  2. A4 Sheet
  3. LED bulb & Switch
  4. Hot Glue Gun
  5. Wires & Power Supply
  6. Scissors
Step 1: Make a Paper Cuboid & Cut Out Square Rings
Firstly cut out the cardboard into square rings as shown. Now using A4 sheet make a hollow cuboid without the two opposite square sides. After that, insert the paper cuboid into the square rings simultaneously as shown above in the picture.
Step 2: Glue Everything and Lighting Conditions
Glue each square ring at equal distance from each other. Now, close the upper side of the cuboid using glue. Now you require a LED light (multicolored or single color) which is to be glued at the bottom of the forming lantern . Secure each and everything with glue.
Step 3: DIY LANTERN IS READY
Step 4: Check Out This Video for Directions
Lighting Challenge
Lighting Challenge
