How to Make Elegant White Pearl Flower Statement Necklace for Wedding
Intro: How to Make Elegant White Pearl Flower Statement Necklace for Wedding
Do you have a friend who is a bride-to-be? Are you searching for pearl jewelry for wedding? Check this elegant white pearl flower statement necklace here, it won't let you down.
STEP 1: Supplies in Making the Elegant White Pearl Flower Statement Necklace for Wedding:
10mm White Glass Pearl Beads
8mm White Glass Pearl Beads
6mm White Glass Pearl Beads
0.2mm Fishing Wire
Magnetic Clasps
Scissors
STEP 2: Bead the Starting Cord for the Necklace
1st, cut a piece of 0.2mm fishing wire (about 100cm), then tie the wire to the magnetic clasp in the middle as shown;
2nd, cross both ends of the wire through an 8mm white pearl bead;
3rd, thread one end of the wire through 3 6mm white pearl beads, then cross the other wire through the last 6mm pearl bead that you just added;
4th, thread each end of the wire through 3 6mm white pearl beads, then cross them through anther 6mm pearl bead and tighten up. You've finished the basic pattern for the necklace strand so far.
STEP 3: Finish the Main White Pearl Necklace Strand
1st, thread a 8mm pearl bead through one wire, and a 6mm pearl bead through another wire, then cross both wires through another 6mm pearl bead and tighten up;
2nd, thread 3 6mm pearl beads through each wire, then cross the wires through another 6mm pearl bead and tighten up;
3rd, repeat the basic beading pattern until you've beaded a proper length;
4th, attach the wire to the other hole of the magnetic clasp, and then thread the wire along several beads in case of slack.
STEP 4: Add 10mm Pearl Bead Bud for the Flower Patterns
1st, thread both wires through a 10mm pearl bead, then cross them through the 6mm pearl bead;
2nd, thread the wires along the beads respectively until they reach the next flower pattern, thread both wires through a 10mm pearl bead and then separate them by crossing them through the 6mm pearl bead;
3rd, add 10mm pearl bud for each flower pattern one by one until you finished the whole flower patterns for the necklace.
STEP 5: Finish the Pearl Flower Statement Necklace
1st, now thread the wire through 2 6mm pearl beads on the flower beads this time, add 6 6mm white pearl beads on the wire, then thread the wire through the middle pearl bead on the next flower pattern;
2nd, add 6 6mm pearl beads on the wire as well, then through the wire through the middle pearl bead on the next pattern;
3rd, repeat above patterns, and finish the whole necklace strand.
STEP 6:
Here is the final look of the elegant pearl flower statement necklace! I just love it!
This elegant pearl statement necklace is also perfect for evening patty. Anyway, I believe you could also make one by following my steps above. Have a nice try!
2 Comments
Liefe 7 years ago
Thank you for posting this! I have a wedding i am going to this fall and i am looking for gifts to give the bride, Might try this as one!
DasiyD 7 years ago
Hi, thanks. I am glad this post is useful for you. :)
