Introduction: How to Make Felt Flower Bouquets With Buttons and Wood Beads
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Searching for flower bouquets? How about these DIY felt flower bouquets? The following Pandahall tutorial will tell you how to make this felt flower bouquet.
Step 1: Materials and Tools Needed in DIY the Felt Flower Bouquets:
jewelry making supplies:
15x2mm 2-Hole Plastic Buttons
Felt
6mm Green Satin Ribbon
13mm Wood Flower Beads
1.5mm Green Aluminum Wire
Iron Scissor
Glue Gun
Round Nose Plier
Diagonal Plier
Step 2: Make the First Felt Flower
1st, cut a piece of pink circular felt, yellow circular felt and blue flower felt (as shown in the picture);
2nd, use glue gun to attach the yellow circular felt onto the blue flower felt. Then, use glue gun to attach the pink circular felt onto the yellow circular felt. Attach the 15x2mm 2-hole white plastic button onto the pink circular felt (as shown in the picture);
3rd, cut a piece of 1.5mm green aluminum wire and twist one end into circular shape. Repeat this step 6 times (as shown in the picture);
4th, attach the green circular aluminum wire onto the back surface of the blue flower felt. Then, cut a piece of blue circular felt that is larger than the green circle aluminum wire;
5th, attach the blue circular felt onto the green circular aluminum wire.
Step 3: Make Three More Felt Flowers
1st, cut a pink flower felt and a red flower felt;
2nd, use glue gun to attach a 15x2mm 2-hole white plastic button onto the red flower felt. Then, glue the red flower felt onto the pink flower felt. Add a green circular aluminum wire on the back surface of the pink flower felt and a pink circular felt onto the green circular aluminum wire (as shown in the picture);
3rd, cut a red flower felt, a green flower felt and an orange flower felt;
4th, use glue gun to attach a 13mm orange wood flower bead onto the green flower felt. Then, attach the green flower felt onto the red flower felt. Attach the red flower felt onto the orange flower felt. Then, add green circular aluminum wire on the back surface of the orange flower felt and an orange circular felt onto the green circular aluminum wire (as shown in the picture);
5th, cut a yellow circular felt, a blue circular felt and an orange flower felt;
6th, use glue gun to attach a 13mm blue wood flower bead onto the yellow circular felt. Then, attach the yellow circular felt onto the blue circular felt. Attach the yellow circular felt onto the orange flower felt. Then, add green circular aluminum wire on the back surface of the orange flower felt and an orange circular felt onto the green circular aluminum wire (as shown in the picture).
Step 4: Make Another Three Felt Flowers
1st, cut an orange flower felt, a yellow flower felt and a green circular felt;
2nd, use glue gun to attach a 13mm pink wood flower bead onto the orange flower felt. Then, attach the orange flower felt onto the yellow flower felt. Attach the yellow flower felt onto the green circular felt. Then, add green circular aluminum wire on the back surface of the green circular felt and an green circular felt onto the green circular aluminum wire (as shown in the picture);
3rd, cut a white circular felt, a yellow circular felt and a green flower felt;
4th, use glue gun to attach a 13mm pink wood flower bead onto the white circular felt. Then, attach the white circular felt onto the yellow circular felt. Attach the yellow circular felt onto the green flower felt. Then, add green circular aluminum wire on the back surface of the green flower felt and an green circular felt onto the green circular aluminum wire (as shown in the picture);
5th, cut a pink flower felt and a blue flower felt;
6th, use glue gun to attach a 15x2mm 2-hole white plastic button onto the pink flower felt. Then, attach the pink flower felt onto the blue flower felt. Add green circular aluminum wire on the back surface of the blue flower felt and an blue circular felt onto the green circular aluminum wire (as shown in the picture).
Step 5: Make the Rest Part of the Felt Flower Bouquet
1st, cut an orange circular felt, a yellow circular felt and a deep red flower felt;
2nd, use glue gun to attach a 15x2mm 2-hole white plastic button onto the orange circular felt. Then, attach the orange circular felt onto the yellow circular felt. Attach the yellow circular felt onto the deep red flower felt. Then, add green circular aluminum wire on the back surface of the deep red flower felt and an deep red circular felt onto the green circular aluminum wire (as shown in the picture);
3rd, cut a piece of green felt and wrap the green aluminum wires with it. Then, cut a piece of 6mm green satin ribbon and make a bow around the green felt (as shown in the picture).
Step 6: Here Is the Final Look of the Felt Flower Bouquet.
The DIY felt flower bouquet can also be created environmentally friendly from recycled felted-wool sweaters and scraps. You can make such a felt flower bouquet to give to your friends and family and watch their smiles grow. So, why not have a try?
