How to Make Firebase Home Automation System Using NodeMCU | in IOT Platform
Intro: How to Make Firebase Home Automation System Using NodeMCU | in IOT Platform
OBJECTIVE OF THIS PROJECT
This project aims to develop a home automation system that gives the user complete control over all remotely controllable devices of his/her home using IOT Android app.
There are many third party online server and platforms available for showcasing the data of your IOT project. But, all of these platforms like ThingSpeak,Adafruit.io,Blynk and IFTT etc but today i select firebase
STEP 1:
STEP 2: Why You Select Firebase
Firebase provides a quick way to persist sensory data collected at the device level, and it works great with the Android APIs, which is supported by AndroidThings. A lot of mobile and device programmers that I have come across struggle with server side programming. Firebase can really help bridge that gap and make it easier.It will be interesting to see developers use its offline features. If you are new to IoT or in general any device that collects data and needs to transmit it over networks, the golden rule to be assumed is that network connectivity cannot be assumed. As a result, you will need to collect the data offline and when network is available, transmit this over to your server. Firebase with its offline feature can really make this simple for a lot of developers.
Firebase has a ton of features including Real-time Database, Authentication, Cloud Messaging, Storage, Hosting, Test Lab and Analytics but I’m only going to use Authentication, Real-time Database.
STEP 3: Ok Lest Go to Project Destruction......
I will devide this project Three part part
1. Creating fairbase account
2. App making
3.Ardunio program part
STEP 4: Creating Fairbase Account
First go to https://console.firebase.google.com/ and login
Click on Add project
STEP 5: Then Show Like This Interface and Give Project Name and Select Country Name
STEP 6: Hear I Select Project Name Home Automation and Select My Country Then Press Create
STEP 7: After a Moment Show This Interface Click on Contention
STEP 8: Then Go to Get Started
STEP 9: Go to Rules and Eadit Code Like Image
STEP 10: Go to Your Setting Then Show Your Api Key
STEP 11: App Making
No tension i will provide you a complete row file for appinventor just click here and download this
no go to ai2.appinventor.mit.edu for open this file
STEP 12: Now Go to Project and Import Homeautomation.aia File on Your Computer
STEP 13: Click on Red Circle Option and Flow That Image Commend
STEP 14: Ardunio Program Part
You have to need some change on your ardunio code
FIREBASE_HOST copy and past on fairbase database
FIREBASE_AUTH copy and past on project setting
and setup your WIFI name amd password
Download ardunio cod from here click here
This tutorial first published on click here
more tutorial about Nodemcu click Here
2 Comments
anokhramesh1 2 years ago
HardikP48 5 years ago
Exception (29):
epc1=0x40205d25 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff0640 end: 3fff0880 offset: 01a0
>>>stack>>>
3fff07e0: 00000001 3ffef5f8 3fff0810 40205d1f
3fff07f0: 3ffe89f4 00000000 3ffef5f8 40205580
3fff0800: 00000001 3ffef5f8 3ffef828 40202457
3fff0810: 3fff157c 0000002f 00000028 3fffbfc4
3fff0820: 0000001f 0000001b 00000000 40207284
3fff0830: 3fffdad0 3ffef5f8 3ffef828 402024d2
3fff0840: 00000000 00000000 00000000 00000000
3fff0850: 00000000 00000000 00000001 4020816d
3fff0860: 3fffdad0 00000000 3ffef84d 40208198
3fff0870: feefeffe feefeffe 3ffef860 40100710
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v614f7c32
~ld
I AM GETTING THIS ERROR CAN YOU HELP ME TO RESOLVE THIS PROBLEM
