Introduction: How to Make Gold Plating Solution.
Gold Electroplating is a method of depositing a thin layer of gold onto the surface of another metal.
Gold plating finds its uses in jewelry, semiconductor industry. It often employed in electronics to provide a corrosion resistant surface.
In this instructable, I am making alkaline gold plating solution which can deposit gold by electrolysis.
Traditionally, such a solutions prepared using extremely poisonous cyanide compounds which are reasonably restricted.
My goal is to make the solution with the publically available chemicals, which are not as toxic to handle. In any case, the final product will be just as poisonous as the traditionally prepared solution.
For this reason, I must warn you. This experiment is extremely dangerous, and I don't recommend anyone without experience to repeat it.
Step 1: Nitric Acid.
If you already have nitric acid at the concentration 50% or above, you may skip this step.
In order do dissolve gold, we will need to prepare aqua regia. It is a mixture of nitric and hydrochloric acid at molar ratio 1/3. Hydrochloric acid sold commercially under the name of muriatic acid. However, nitric acid is restricted for public use. Therefore it has to be prepared from available chemicals.
There are quite a few ways to make nitric acid at laboratory conditions. On my youtube channel, I am covering two methods.
First, by reacting sodium nitrate with the sulphuric acid followed by distillation. This process produces acid at the concentration of above 90%. At this concentrations, nitric acid is highly corrosive and fuming a toxic nitrogen dioxide gas.
And the second method, which less dangerous, is a concentrating very dilute nitric acid that is commercially available for the public. I am using fractional distillation to concentrate nitric acid from 30% to 50% concentration. However, I could achieve the azeotropic concentration of 68% if I used proper fractionating column.
For the gold plating solution, this method of nitric acid preparation is favorable as it is relatively safer.
For more details, please watch the video.
Step 2: Making Gold(III)Chloride
To make gold chloride, we need to dissolve gold in aqua regia. (mixture of nitric acid and hydrochloric acid at molar ratio 1/3)
In my case, I have 18K gold scrap, but the purity of gold makes no difference as gold will be purified to 24K during the process.
The reaction of gold and aqua regia produces toxic fumes so the process must be conducted outside or in the fume hood.
It takes around 20 minutes for gold to dissolve at room temperature. At the end of the reaction, we have the solution of dissolved gold and copper compounds and solid crystals of silver salts.
Now this solution needs to be filtered, to separate solids from the liquid.
Next, the gold is precipitated out of the solution in its elemental form by the addition of sodium metabisulfite solution.
During the addition, the toxic sulfur dioxide gas produced, so this process can only be conducted in the fume hood or outside.
Once there is no more visible reaction happens during the addition of the sodium metabisulfite, that would mean all of the gold has precipitated.
And the last step is to separate the solid gold and dissolve it in aqua regia once again. This time there will be no solids and the solution will be the red color. Now the acid needs to be evaporated at 120 degrees centigrade to obtain red crystals of gold(III)chloride.
Step 3: Final Step, Making Gold Plating Solution.
In the final step, we need to make a strongly alkaline solution of gold chloride and potassium ferrocyanide.
Using this solution and electrical current, we can deposit gold over the surface of other metals.
This solution contains gold cyanide ions, which are extremly poisonous.
Under no circumstances, this solution can be mixed with acids, as it will release hydrogen cyanide gas. (I can't even find the correct word to describe the toxicity of this gas)
Neither it can be disposed of down the drain.
For the details and demonstrations, please watch the video.
If you like my videos, why not subscribe to my youtube channel? I am uploading videos on the regular basis.
Thank you for the attention.
17 Comments
7 months ago on Introduction
This instructable is not very useful due to the references to "watch the video for more information" is not possible. The videos are no longer available.
Tip 2 years ago
The last step calls out for potassium ferrocyanide. PF by itself won't do squat. What you want is the real deal, the highly toxic and equally effective potassium cyanide. How do you obtain PC, even though no one is selling on eBay? Easy! If you already have PF, you're half way there!
Step 1. Acquire metal crucible. Add PF and sodium hydroxide in a1:1 ratio to the crucible.
Step 2. Apply hear directly to this mixture (you'll find out soon enough that your stove won't cut it - you'll need propane for this task. Liberally hear the crucible and directly to the top of the mixture with it).
Step 3. Heat until the mixture becomes a frothy, black liquid (about 120 seconds of heating). You'll start to see pops of flames about out of the boiling mass. That's hydrogen cyanide, a highly flammable gas. Don't worry about breasting it in; once it burns it disappears.
Step 4. Don't heat to redness. You wanna hear just at that moment when it turns date brown, and your particles of PF just dissolved now when the reaction is complete, you may carefully (over 1,000*C we're talking here) dump the booking black, highly caustic solution over ceramic tile. If you ignore this step you'll spend hours removing it from the crucible. Why?
Step 5. Pick up the sodium cyanide and iron sulfide clumps and add to a glass beaker charged with water, just enough to facilitate dissolution.
Strep 6. When your solids have completely dissolved, filter.
Question 3 years ago on Step 3
In preparing my gold chloride,do I have to add any chemical again,cos I tried one but after I had my gold chloride,I added only distilled water but and when I tried plating, solution was reacting with the anode
3 years ago
Is there a way to apply thicker, heavier or multiple layers of gold when plating?
Hello,,i trésor From DRcongo n i will need to travel n Côme to u so that i van learn in thé Nice way how to make a gold solution plating ,even how to start plating .what can i do to contact you personnely to discust about the course from you
Question 3 years ago on Introduction
Hello,, i wanna learn how to make a gold plating solution but i ready to travel and meet a professionnel ,who must i contact please
3 years ago
Gold plating...... I scraped off the gold afterward and got 0.75 g of gold from the foil. They say cellphones have only 0.035 g in a cellphone (gold) but I got mostly gold from it.
Potesiam ferrosinaid ko kis kisme dale
Tip 3 years ago on Step 3
Good
3 years ago
Could you plate platnium with a copper silver alloy if silver was plated with trace silver nitrate?
Question 4 years ago on Introduction
Is it used brush plating(gold solution)?
Question 5 years ago on Step 3
If i have pure gold than can i skip 1st two steps filteration and crystalisation and how much current and what strength liquid should i make for plating gold jewelry for finishing systems.
5 years ago
Hi sir,
i have a plant to recoat covering chain so i need to know the process,where can i get those manual and process solution,
6 years ago
If oil isn't a good idea something non flammable like sand.
6 years ago
Hmm Have you thought of a good hot plate that can reach 500 degrees C or greater and using an Oil bath. Unless the nitric acid reacts with the hot oil this may help control the heat output. Also you should mention what would happen if Nitric acid heat up too high (formation of toxic nitric oxide and nitric dioxide gas). Nice Job though.
6 years ago
Hello!
Thank you for your guide! Its come in quite handy. I have a question tho, is there any way to plate silver onto copper? Also, does this only work for playing gold onto silver? Is there a diffrent solution needed to plate gold onto copper?
Thank you for your time!
Reply 6 years ago
Hi, thanks for your question. It is much easier to plate with silver, and the process does not require the use of poisonous cyanide compounds. However, I've never silver plated before thus my knowledge is only hypothetical. You need a solution of silver nitrate as the electrolyte, and the negative terminal of electrolysis must be pure silver.
If you don't know how to make silver nitrate you can check out youtube channels (NurdRage, or NileRed) they both have great videos on making silver nitrate.
I am not exactly sure about the concentration of silver nitrate solution. Personally, I would dissolve 1g of silver nitrate per 100ml of water. The deposition of silver may take a while, as the conductivity of this solution will be very low. So if thinking logically, the more concentrate the solution of silver nitrate the faster it will be depositing the silver.
The gold plating solution that I made, can also be used to deposit gold on some other metals including copper, stainless steel, brass etc. However, it does not seem to work on zinc metal, and I couldn't figure out why.
