Introduction: How to Make Henna Paste and Apply to Skin
Henna is a great way to create designs on your skin without the permanent effects of a tattoo. Through this tutorial I will teach you how to make your own henna paste in a fun, easy way. After the henna is made, you can use your own creativity to create absolutely any design you can think of!
Step 1: What You Will Need
What You Will Need
• Fresh henna powder (I found this at a local Indian grocery store)
• Lemon juice
• Sugar
• Essential oils (I used tea tree)
• Non-metal mixing bowl and spoon
• Plastic wrap
• ZipLock bag
• Decorating tip
• Rubbing alcohol
• Olive oil
• Mild soap
• Gloves for handling henna
• Tape
• Scissors
Step 2: Measure Out 1/4 Cup of Sifted Henna Powder Into a Bowl
• Buy henna with a greenish-brown tint
o Too brown=old henna and won’t leave a good stain
o Too green=may have added dye to make it look fresh when it really isn’t
• Store leftover powder in the freezer to stay fresh
• Vary the amount of henna you make to the size of your design
• Sift henna to get rid of chunks that could clog the applicator tip
Step 3: Add ¼ Cup of Lemon Juice While Stirring
If needed add additional lemon juice until the consistency is between toothpaste and pudding
• If substance appears too thick after adding lemon juice, Slowly add additional lemon juice to avoid getting too runny
• Smash all lumps beginning to form while stirring
Step 4: Stir in 1 ½ Tsp. of Sugar and 1 ½ Tsp. of Essential Oil
• Use oils that contain terpinols (I used tea tree)
• After adding in oil and sugar the texture should be silky
Step 5: Cover Henna With Plastic Wrap
Rest for 24 hours at room temperature to draw the dye out of the henna
-The henna should appear similar to the last step
-Possibly will appear a little thicker
Step 6: Once the Henna Has Set, Scoop Out the Dye Into Your Applicator
a. I washed out a tip from an old decorating gel tube,
b. cut the corner of a Ziploc bag,
c. and placed the tube into the bag
d. Tape the bag around the tube to secure
e. Spoon out henna into the applicator
Either use henna immediately, or freeze until use
Step 7: Wash Skin With Soap and Water
• If skin is oily, apply additional rubbing alcohol
Step 8: Position Your Tip Over Skin
• Use proper protection when using henna: it will stain skin and clothes
Step 9: 3. Create Your Design!
Hands and feet stain darker
a. Websites to view design options
i. http://slodive.com/inspiration/henna-tattoo-designs/
ii. http://pinterest.com/ladybird66/henna-tattoo-designs/
b. Apply pressure gently until you get a feel of how fast the henna will come out
c. Clip the tip back if it does not come out well enough
d. I would recommend staying away from central body parts that don’t stain as easily
Step 10: Let Design Dry
• Cracking of the henna is a good thing
Step 11: Wrap Your Design With Plastic Wrap
Keep covered for at least 10 hours
Step 12: Add Olive Oil to Design After Unwrapping
Step 13: Remove Excess Flakes With a Mild Soap and Water
• Gently blot design when removing the excess flakes after it has dried so you don’t shorten the life of the design
• The design will turn from a lighter orange shade into a reddish/brown shade within 12 hours of removing flakes
YOUR DESIGN IS COMPLETE!
40 Comments
Question 1 year ago
What If you don’t live in Indian and how are you supposed to get the Henna Powder? To style the Henna on your skin
Answer 1 year ago
You can buy henna from amazon to make the paste, this is what I buy and I love it https://amzn.to/3krwKTm
9 years ago on Introduction
How long does this last?
Reply 1 year ago
Same. Because of my skin the Henna took 1 hour to dry before I can take the flakes off
Depends on various factors like your skin, oils, quality/type of henna and your mixing ratio but usually about a week. A few days minimum, a couple weeks maximum.
6 years ago
Why do we use essential oil and if we don't what happens? Anyone?
Reply 1 year ago
Take your fingers and get rid of the part that has dryer for 1 hour
5 years ago
You don't have to leave it on super long. You put it on and let it dry (an hour) and then dab more lemon juice on. You can maybe get it darker with a second dab, but it should be fine. Once it is dry, nothing more is happening and you can flake/wash it by any means.
Fingers and toes get darkest, don't know why.
Reply 1 year ago
They didn’t say anything it just says to wash it of with water to get rid of the part that was dying
Question 3 years ago on Step 3
what if I don't have lemonds
Answer 1 year ago
Really🤨. What if it don’t have any lemons. It’s called go buy some or ask your parents or somethings?
Question 1 year ago on Step 12
Why put olive oil on the design after it has dried and sat? I also don't ever put a time limit on anything. I do my design and go on with my day! Of course letting it dry without touching it on anything. Then after it dries, I just let it be and flake all off on it's own. I never peel it off, wash it off or put anything on it. Works good for me and so much easier than wrapping it and peeling it off myself. Lol
Question 1 year ago
What are terpinols? What other essential oils have terpinols? What do they do for the henna tattoo paste? Like why use oils with terpinols in them?
5 years ago
Mine was on only 2.5 hours, this is two days after it was done. My wife did more lemon juice after 1 hour.
6 years ago
thanks for that
6 years ago
thanks for that
I don't use cup measurments where I live...
So does anyone know how much it is in grams?
Reply 6 years ago
20 grams
Reply 7 years ago
1cup is 227 grams
http://dish.allrecipes.com/cup-to-gram-conversions/
6 years ago
http://mehndinhenna.com/ is a site where you will find answers to every question related to henna and mehndi and not only that here you can learn henna they provide practice sheets for free.
