How to Make Indonesia's WajanBolic or PanciBolic (USB)
Intro: How to Make Indonesia's WajanBolic or PanciBolic (USB)
My third instructables! Now I'm gonna teach you all Indonesia's Wifi Antenna made of wok.
NOTE: I didn't invent this cool thing.
STEP 1: Gather the Parts!
What you need:
1. Extended USB cable (click here)
2. Wok or the cover of a saucepan. (I use the cover of saucepan, because it's lighter).
3. USB WiFi
4. 3" PVC pipe. You need at least 1m. (depending of your wok size)
5. 1.25" PVC pipe. You need just a little of it, at least 5" long. Cut the middle (like in the picture)
6. Doff for 3" pipe (doff=pipe cover, holed in the middle. One of them connect to 1.25" doff using screw)
7. Doff for 1.25" pipe (stick aluminium foil inside then hole in midle, the other don't need to be holed)
8. Aluminium foil
9. Drill
If you don't understand, see picture
3. USB WiFi
8. Aluminium foil
9. Drill
STEP 2: Suck the WiFi USB!
Suck it up on the 1.25" PVC pipe! (picture)
STEP 3: The Hardest Part...
Get the 3" PVC. Count the focal point. Make a mark in the focal point. Then put aluminum foil EXCEPT for the focal point. Then make a hole around 5.3cm from the edge for the USB wifi. Insert than USB Wifi in.
STEP 4: Almost Done!
Close the 3" PVC pipe (the one with the 1.25" doff).
STEP 5: Drilling!
Drill the wok and screw it with the another 3" doff.
STEP 6: Secure It Together!
Secure it (picture)
42 Comments
suryawarior44 8 years ago
kampret wajan bolic masuk instructables :v
kikinick1234 9 years ago
wah antena booster versi indonesia mantap! "keep up the good work!" :)
poro 9 years ago
wuih...wajanbolic mlebu instructables...
pokoke makyoosss..
bantu sundul ya gan.. :)
dragonclan1tnt 12 years ago
dan moulton 15 years ago
jokoh 12 years ago
huang.wencong 15 years ago
where D is diameter and d is depth.
A doff is the cap of the PVC pipe. That's what you call it here in Indonesia.
aredee 12 years ago
transitionality 14 years ago
However, I don't see why you have the 1.25'' pipe piece in there. What does it do? Wouldn't the design work just as well without that piece?
tongak 12 years ago
CMIIW
tezakuri 13 years ago
sunarno 15 years ago
legless 15 years ago
fegundez1 14 years ago
zgeng 14 years ago
indonesia jaya...
bayucandra 14 years ago
But the bad news, standard calculation have been made in Indonesian language, you need a dictionary maybe :).
advante 14 years ago
arzarach 14 years ago
chiangkool 14 years ago
grimrp3r 14 years ago
