Introduction: How to Make Laser Signs for Safety Escaping
Safety escape laser signs can clearly point the way to safety, helping everyone quickly find the way to safety exit. Making the laser signs for a workshop or charity fundraiser could save many lives!
Now is going to use a Thunder Laser system to make a laser Safety Escape Sign. Let’s start to explore fun with the laser!
Material: 1.3mm two-tone ABS sheet gold to green
Laser head: standard head
Laser engraving machine: Thunder Bolt Pro32 55watt
Step 1: Setting Parameters:
Processing Mode:
Engraving speed: 1500mm/s
Engraving power: 15%
Engraving passes: 3
Cutting speed: 40mm/s
Cutting power: 60%
Why engrave it 3 times at high speed and low power? Well, we don’t want the ABS turning into a warped potato chip. So to keep the laser signs flat, don't set the opposite parameters!
You can also draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your laser engraving machine.
Step 2: Assemble It:
Place the ABS on the work table of the laser engraving machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.
Get the laser signs cut out and scrub it with a brush and water to remove dust, Let’s do it by yourself.
#Laser Engraving #Laser Cutting #Free Laser Files #Laser Crafting #Escape Route Signs #ABS Sheet Craft #Custom Laser Signs #DIY Projects #Craft Tips #Useful Signs #Smart Workshop Hacks #Public Safety Solutions #Workshop Safety
