How to Make Led Strip Flashing Easy
Intro: How to Make Led Strip Flashing Easy
How to make led strip blink easy
STEP 1: Usb Led Strip From RGB Strip
The easiest thing to make an led strip blink, in this case an usb led strip is to have or buy a controller from that RGB led controller,a power supply,power bank,or any USB power outlet and the led strip itself
STEP 2: RGB Controller Close Look
As we can see in this picture here the controller has R-G-B and 5+ so we have 3 channel of negative and one positive so we can connect 3 usb strips or 3 usb flashlights, led bulbs anything that is powered by USB(5v)
and we will need a connector i have this from an old dvd,orif you whant the propper connector you can google them.
STEP 3: Rgb Controller Test
We will plug in the controller in any usb power source and we will test the pins you should see on the multimeter 4-0-4 volts or close to this range and we can connect our led strip to any of this R-G-B in the video at the end of this tutorial i have connected to the R
STEP 4: How to Make Led Strip Blink Easy
How to make any led strip blink easy parts:
Led strip(5v-12)
Rgb controller
http://s.click.aliexpress.com/e/bJpLyC0o
Usb power bank
Wires
STEP 5: Led Strip Blinking
- As you can see we have connected to the controller and our channel is working perfectly you can connect to any of the R G B as long you will take in to consideration that R G B are the minus terminals
