Introduction: How to Make Mini Radar | Arduino Based
$2 for 10PCBs (24 Hour Fast Build): https://jlcpcb.com
Hello friends in this video I have made a Mini compact Radar with display, for that I have used HC-SR04 ultrasonic sensor, this sensor emit ultrasonic sound which came back to sensor after reflecting from an object,
all the data visualization is displayed on 1.8" ST7735 display, if any object detect by radar it'll show in display in red line.
For this project I have develop a custom made PCB and get it manufactured from JLCPCB.com
JLCPCB is one of the top leader in PCB manufacturing.
Step 1: Video
Have a look to this complete tutorial video
Step 2: Material Required
There is four main components of this project
Arduino nano is the braing of our project
HC-SR04 is ultrasonic sensor this sensor emit ultrasonic sound waves which human can't listen , this sensor generate some value in proportion to the reflected ultrasonic sound waves from the object, on this we can also tell the distance of object from the sensor.
SG90 micro servo is used to rotate ultrasonic sensor in 180 deg
ST77535 display is our monitor to visualize all data on screen
Arduino nano :- https://amzn.to/2Eq3tSK
HC-SR04 ultrasonic sensor :- https://amzn.to/2SEU4vQ
SG 90 Servo :- https://amzn.to/2NG807N
1.8" ST7735 Dispaly :- https://www.aliexpress.com/item/NEW-1-8-inch-4-IO...
Step 3: Circuit and Code
Code and other details are found on the link
https://github.com/sandy9159/Arduino-based-Mini-radar-HC-SR04-ST7735-Display
Step 4: 3D Files
Complete 3D files will be available at thingiverse
https://www.thingiverse.com/thing:3465440
I have a Tevo Tarantula printer i have printed all parts on dark green PLA at 50 % infill
After printing all the parts or you can design your own model
if you don't have access to a 3D printer then you can use material like acrylic sheet or cardboard sheet.
Do the wiring as shown in circuit drawing and load the code to arduino.
You radar is ready to work if you face any problem please feel free to comment below
Epilog X Contest
12 Comments
Question 4 months ago on Step 1
Is it possible to get the gerber file you used to make the green board?
4 years ago
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
U:\Arduino\sketch_may02a\sketch_may02a.ino:4:20: fatal error: Ucglib.h: No such file or directory
#include "Ucglib.h"
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
HELP ME PLEASE!!
Reply 4 years ago
when i compile it to arduino this error is what i get
Reply 4 years ago
i want to do this on an ordinary arduino, can you help write the code for me?
please contact me at halfoudari3@gmail.com or whatsapp +1 5037993957 for payment.
Reply 11 months ago
so....did you figure out you were missing the library or did you miss the deadline for your grade? The error code tells you exactly the problem, next time, as a first step, type the error code into google. Then realize copy and paste exist so you didnt actually have to type it letter by letter. Do you often just buy your way out of trouble? Geez, I sure hope your not studying to become an architect or something.....
Tip 11 months ago
RADAR - RAdio Direction And Ranging. It does not use radio, it is not radar. It uses ultrasound. Its SONAR - SOund Navigation And Ranging.
For the love of STEM, USE THE CORRECT TERMINOLOGY INSTEAD OF CLICKBAITING!!! Inspiring newcomers to use incorrect terminology instead of learning the technology involved makes for muddy communication. And science is where cmmunication should never be muddy. Do better, be better, stop with the simplified incorrect wording. And that is to all makers, not just this OP.
I will say, I dig the display.
1 year ago
It seems that the 3D print files are not complete. Any idea where I can find the base? thx
1 year ago
link yok?
3 years ago
I want to make same project with ILI9341 TFT LCD display and adruino nano. Please let me know if there is any change and how to connect display with adruino. Thank you very much..
4 years ago
Is it just me, or does the display image appear to be reversed? like when the sensor is rotating left, on the screen you see it rotating right.
4 years ago
I like how the enclosure makes the sensor look like eyes. :)
Reply 4 years ago
thanks
