Introduction: How to Make Russian Juggling Balls
In this tutorial I will teach you how to make the most affordable Russian Juggling Balls available. These Russians are a little different than usual because they are textured as opposed to the normal smooth Russian ball. They are also a tad bit smaller than a normal Russian ball, which makes them easier to handle. Watch the linked video for more details and demonstration.
Step 1: What You Need
Franklin Aero-Strike Plastic Baseballs: http://amzn.to/1qXi5Rr
Salt: http://amzn.to/1SGpbQ3
Scissors: http://amzn.to/1VujpYG
Tape: http://amzn.to/1qLz6xr
120 Grit Sandpaper: http://amzn.to/22zi5Cq
Paper Plates: http://amzn.to/22zi1Tm
Box Cutter: http://amzn.to/23BomUb
Glue Gun: http://amzn.to/22zhr86
Gram Scale (This is the one I use in my videos): http://amzn.to/23BomUb
Sheet of Paper
Step 2: Make Funnel
Cut a pyramid shaped piece out of the sheet of paper about 4 inches wide at it's widest point and a quarter of an inch wide at it's slimmest point. "Wrap" that paper into a funnel shape. Take a piece of pre-cut tape and tape it to retain it's shape.
Step 3: Cut Hole in Ball
Take the box cutter and cut a hole out of one of the practice baseballs (cut around existing hole). Try to cut it out in one piece to make the sealing process easier.
Step 4: Fill With Salt
Using the funnel, transfer salt into the ball (place paper plate beneath to catch extra salt). You may have to fill up the funnel with salt, then wait for it to drain into the ball, then repeat the process. Once you get it to around the weight that feels right to you, place it on the scale to see how close you are. I make my balls 100 grams, but you can fill them as heavy or as light as you need. Add or empty salt as needed.
Step 5: Seal Ball Closed
Once you have filled the ball to your desired weight, place the plastic you cut out earlier back in place. If you didn't cut the piece out in in once piece, you can always cut a new piece from another ball. Take the pre-heated glue gun and rest the metal tip on top of the seam and gradually remelt the plastic together. Add more pieces of plastic as necessary.
Step 6: Smooth Surface
Once the plastic has cooled, take the sand paper and smooth out the surface. Repeat this process for each ball. (Hint: It's faster if you do them all at the same time.)
Step 7: Finished!
That's it! You have learned to assemble the most affordable Russian juggling balls. Juggle away! Don't know how? The linked videos provide some basic tutorials. Have fun!
3 Comments
Tip 3 years ago on Step 7
Thank you very much for sharing your instructions.
I modified the method a little bit. I do not have to cut an extra hole into the balls, because I use the small hole to fill in quartz sand with a self-made funnel.
You can use any disposable plastic cup or paper coffee mug. Drill a small hole into the bottom of it. Then place the bottom of the mug with the hole on top of ball and make making sure that the hole in the bottom of the mug is exactly covering the small existing hole of the ball. Now just fill in the desired amount of quartz sand.
Afterwards I sealed the small hole with a tiny piece of plastic from a ball I cut in half using a temperature controlled soldering iron (adjusted to 150°C).
6 years ago
sick bro
6 years ago
Fun. I am going to have to show this to my son. He will love it.
