Introduction: How to Make Solar Rechargeable Light
you need a solar panel 4 to 6 volts
old phone battery with protection circuit a diode no zener
switch and a LED or a LED array
Step 1: Attach the Diode to the Solar Panel
make sure the white line is facing away from the solar panel
Step 2: Hot Glue the Switch to Solar Panel
Step 3: Step 3
the battery and the solar panel share the same ground along with the LED also begin soldering led to be switch
Step 4: Step 4
positive of the battery goes to the other side of the diode
Step 5:
positive of the LED goes to where the battery positive goes and attach a wire to the switch AND YOUR DONE
Step 6:
test if the light comes on when you flip the switch put it in the sun and see if the battery voltage increases
Step 7: Cover Up the Electronics With a Case or Tape
cover up the electrons with a case or tape
Step 8: DONT FORGET STEP 7
