Introduction: How to Make Wired Headphones Wireless DIY
Nowadays, everthing is wireless all gadgets like mouse , keyboard, headphones, speakers etc. So I had got an idea to make wired headphones/ earphones wireless at home in few bucks with the old headphone . Wireless headphones are very costly but cheap ones are also available , sometimes they works well and sometimes it get damaged due to some problems. In this instructable I will show how to make your wired headphone wireless if you are having one at your homes instead buying the wireless headphone. You just need to spend $3 or less to make it wireless.
It is very easy to make it as high knowledge of electronics is not required in this instructable like soldering, making circuits etc.
Step 1:
- Headphone / earphone
- Bluetooth Receiver / Sensor
- Scissor
- Tape
- Adhesive glue (If required)
Step 2: Follow the Video or Steps Below to Make It Wireless
The main thing needed is the Bluetooth receiver/ Sensor which costs not more than $3 & a power source for it. I had used power bank as a power source for the bluetooth receiver but any other power source can be used if you don;t have a power bank
Take care that you should buy Bluetooth receiver with usb & sound jack port as seen in the above pic
Step 3:
Next step is the fix the Bluetooth receiver/ Sensor & power bank to the headphone (it is not necessary to fit it to headphone, it is as per your choice)
To do so take the headphone & tie the wire together as shown in the pic.
Step 4:
Next take the power source i.e, power bank or something that you use as a power source for the bluetooth receiver/ sensor & locate a position where you can stick it Note that don't stick it to the place where headphone are used to adjust to wear it. Use tape to to stick the power bank to the headphone
If you wanted to stick it permanently use adhesive glue between the power bank & the headphone and then wrap it with the tape to the headphone .
Step 5:
Next plug the Bluetooth receiver/ sensor to the usb port of the power bank & plug the audio jack to the Bluetooth receiver and it will get activated
And finally it looks like in the above pic.
To wear it
Step 6:
Next step is to pair the bluetooth receiver with the phone
To pair go to bluetooth setting of the phone & turn it on. Search for devices , you will find audio devices with headphone icon as shown in the pic. Then connect the audio device. It will automatically get connected to the headphone.
Finally enjoy the music..
Step 7:
Like this you can connect earphones and even speakers.
It can be used to make stereo of your car also wireless with the help of Bluetooth receiver/ sensor. For this you have to plug the blue tooth receiver/ sensor to the usb port of the stereo and plug the audio jack of the stereo to the back of the bluetooth receiver which otherwise is used to connect the mobile and follow the same procedure to pair the phone.
