Introduction: How to Make ZERO From Nightmare Before Christmas
My way of making ZERO
3 pipe cleaners
A red sharpie
A black sharpie
A red ball of yarn
2 plastic spoons
A white table cloth
1 piece of construction paper
Black paint
1 plastic cup
A ping pong ball
Hot glue and hot glue gun
Scissors
A glue stick
A red sharpie
A black sharpie
A red ball of yarn
2 plastic spoons
A white table cloth
Black paint
1 plastic cup
A ping pong ball
Scissors
A glue stick
Step 1: Nose
Get the ping pong ball
You are then going to get the red string and hot glue the very end of it to the ball
You then are going to wrap it around as many times until the ping pong ball is covered with red string
After the ball is fully covered you then get the scissors and cut it
After you are going to hot glue the part you cut to the ping pong ball
Step 2: The Under Body
Then you take your plastic cup
You are going to want to take 1 piece of construction paper and wrap it around the cup until the top makes a point
After you are going to want to glue the paper to each other so it holds it’s shape
You are going to then have extra paper hanging off the cup and so you will want to cut that off with scissors
Then glue the remaining of the paper to your body (the cup)
After you’ve done that you are going to want to paint everything black by using paint and a paint brush
Step 3: The Body
You are going to want to get a white table cloth
Then you will cut a square section like in the picture I provided with scissors
Step 4: The Nose Hold
This is going to help with the nose in step 6
During this step you are going to want to place your cup in the center with the point on the cloth
You are then going to get a marker and trace around the point and it should make a circle
After that you are going to fold your cloth in half and cute your circle out with scissors
Step 5: Adding the Nose
After cutting the cloth you are going to want to get a glue stick and glue it around the point of your body
You after that you are going to want to add hot glue to the point and glue your nose on
Step 6: The Ears
You are going to want to get your two plastic spoons
You are going to cut the top part off and color it with black marker
After you are going to hot glue them to where the end of inner body is
Step 7: Adding the Arms
Underneath you are going to get the pipe cleaners and fold them to make them into arms
You will put the cloth over and it will give it a ghostly look
With pipe cleaner as well you make the red collar to put around your ZEROS neck
