How to Make a 1920s Black-&-White Stylized Sock Puppet Inspired by Two-Tone Shoes
Intro: How to Make a 1920s Black-&-White Stylized Sock Puppet Inspired by Two-Tone Shoes
List of Materials:
One Black Ribbon
One or more Sheets of Black Craft Foam
A Black Dress Sock
Black and White Felt with White Buttons
Some sort of Bottle or Round Container to Wrap your Sock Over
And of Course...hot glue and hot glue gun
One Black Ribbon
A Black Dress Sock
STEP 1: Step #1
Take your sock and wrap it over your bottle or container like so.
Then take your white felt and cut out a large triangle with a pair of scissors.
Take your hot glue gun and glue the triangle onto your sock.
STEP 2: Step #2
Wrap a piece of black felt around the base of your sock and glue it down.
Fold the top corners of the black felt to give it a jacket look.
Glue 3 white buttons down the outside of the jacket and glue 1 button on your white triangle or shirt.
STEP 3: Step #3
Make two small triangles from your white felt and glue them together to give it a more 3D look, and repeat the process.
Glue both triangles on the chest of your puppet and place a button between the triangles.
It should look something like this last picture
STEP 4: Step 4
Once you've completed your little tuxedo, you are now ready to finish this puppet.
First off, place two white buttons where you want to put the eyes and glue them down gently.
Take a round container with one side wider than the other and draw two circles, also one bigger than the other.
Then cut out a rectangular piece of black foam and roll it before you glue it together. Once you got this done, place the the smaller circle on top and the bigger circle on the bottom to make the base of your top-hat.
Take your newly made hat and glue onto the top of the sock's head. I personally made mine so that the hat covers a little bit of one eye, but you don't have to do that. Be creative, find what works for you. You could also simply buy a tiny top-hat from your local craft store...if you have one. I don't, that's why I made one.
STEP 5: Step #5
Cut out a tongue shape piece of white felt and with a permanent ink marker, draw a line down it and glue it into the mouth of your puppet. If you find you're having a problem with the mouth, use staples or a pom pom to shape the mouth properly.
Then go back to your tuxedo and cut a coat-tail pattern out of it in order to give your arm more room when you stick your hand inside. If you don't, it'll be very tight.
And there you have it, a black-and-white puppet inspired by two-tone shoes. Now go on and do all sorts of silly stuff with it
