Introduction: How to Make a Beaded Snowflake Ornament
Beaded Christmas snowflake ornaments to share with you! If you know some beading skills, this snowflake ornaments can be easily finished. Let's check it out!
Step 1: Materials:
Step 2: Make the Center Circle of the Beaded Snowflake Ornament
1st, cut off about 70cm tiger wire, slide five 8mm pearl beads onto the wire;
2nd, cross the both wire ends to another 8mm pearl bead and tighten wires, keep one wire 60cm for continuing beading.
Step 3: Make the Petals for the Beaded Snowflake Ornament
1st, use the 60cm wire as the working wire, slide a 4mm pearl bead and a seed bead onto the wire, add a 4mm pearl bead and a seed bead again, then add four seed beads and three 8mm pearl beads alternatively;
2nd, pass through the wire back to the 2nd seed bead and tighten wires;
3rd, slide a 4mm pearl bead and a seed bead onto the wire, add a 4mm pearl bead again, pass through the wire back to the 8mm pearl bead at the top of the center circle and tighten wires; now you have got the first petal;
Step 4:
4th, thread the wire clockwise to the next 8mm pearl bead, then repeat the processes the 1st and the 2nd in this step;
5th, slide a 4mm pearl bead and a seed bead onto the wire, pass through the wire back to the 1st 4mm pearl bead of the last petal and tighten wires;
Step 5:
6th, repeat processes the 4th and the 5th to make another three petals;
7th, thread the wire clockwise to next 8mm pearl bead again, continue to thread the wire to the last 4mm pearl bead of the first petal, add a seed bead, a 4mm peal bead and a seed bead to the wire, then do the rest as the same with other petals.
Step 6:
Conceal the redundant wires by passing the beading path; now, a beaded snowflake ornament is done.
3 Comments
Question 2 years ago on Introduction
What size tiger wire should I be using? Could someone give me an answer soon since I'm trying to get a head start on Christmas??
What are the dimensions of the snowflake?
Question 4 years ago on Step 2
Just wandering approximate size of the finished snow flake
