Introduction: How to Make a Better Bristlebot!
A bristle bot is a fun little robot that you can make out of a few things around the house.
They are really quite easy to make and are a lot of fun!
Many Bristlebots are the same, mine is different!
I will be teaching you how to make a Bristlebot using a Pulsar Oral B Toothbrush!
These new Bristlebots also look really cool!
Step 1: Supplies & Tools
1. Pulsar Oral B Toothbrush
(the reason we need this brush is because there is a tiny vibrating motor inside which will be powering our little robot!)
2. Double Sided Adhesive Tape
3. 1.5V Button Cell Battery
Tools
1. Wire Stripper
2. Scissors
3. Tiny Scissors
4. Pliers/Wire Cutter
5. Heavy Object (book)
Step 2: The Toothbrush
The first thing you will do it take your toothbrush and remove the battery cover and take out the battery inside it.
Hey! Now you have a spare AAA battery! (Figure 1.1 & 1.2)
Use your pliers to remove the guts of the toothbrush. This may take some force but don’t worry you won’t break the motor. (Figure 1.3 & 1.4)
Once you have removed the guts of the toothbrush take your pliers and use the wire cutting part to cut the head of the toothbrush of off the body. (Figure 1.5)
The bristles are facing strait down but we wish for the to have an angle.
Place a book on top of the toothbrush head.
(Make sure the bristles are facing towards the uncut end.) (Figure 1.6 & 1.7)
Step 3: The Guts!
Now take the guts of the toothbrush and bend back the plastic encasing the motor, and also pull off the plastic covering the blue wire. (Figure 2.1 & 2.2)
Should you cut the blue wire or the red one?... Both!
Cut both of the wires with your small scissors and remove the motor from the plastic. (Figure 2.3)
Now that you have the motor you will need to strip the plastic off the wires. Do this using a wire stripper. (Figure 2.4)
Step 4: Putting It All Together!
You can now take the brush head out from under the book and see if the bristles are staying angled. (Figure 3.1)
Take your double sided adhesive tape and cut it so it fits on the brush head. (Figure 3.2)
Stick one side to the brush head and then place your motor on the tape. Place the blue wire on the tape and then place the negative side of the battery on top of it so that the wire and battery connect. (Figure 3.3)
Your Done! When you want to turn on the little critter just bend the red wire over so it is touching the side or top of the battery! (Figure 3.4)
Step 5: Tips
After playing with the Bristle Bot for a little bit you may start to notice how it likes to fall over quickly.
An easy way to fix this problem is to take the toothbrush head and make it wider by pulling it apart slowly.
It is quite easy because the toothbrush head is already cut.
This fixes the problem with falling down.
Another fun thing I started doing was dipping the bristles in paint and creating art work! :) (Figure 4.1 & 4.2)
I hope you enjoyed my Instructable on creating a fun little Bristle Bot!
Nostalgia Electrics Ultimate Party Challenge
MakerBot Challenge
1 Person Made This Project!
- ImpactProps made it!
16 Comments
4 years ago
i can't find a button battery in in my school
4 years ago
I got a gr8 name
4 years ago
I got a gr8 name
4 years ago
I got a gr8 name
4 years ago
I got a gr8 name
4 years ago
I got a gr8 name
4 years ago
Hi
9 years ago on Introduction
Still cant believe that someone took repackaged the bristlebot idea and is selling them for $8 at the cheapest under the name "Hexbugs"
Reply 6 years ago on Introduction
absolutely.............just right and in india they sell it for 400 rs which is a lot for us
7 years ago on Introduction
+1, FTW
8 years ago on Introduction
i have made mine today,it's brillient.
I know right!!! i was sooooo happy when i saw something that did not cost 100 dollars!! ^-^ ^-^
This is awesome! I love the idea of drawing with it.
Thanks!
Yea I enjoy it!
It's fun to tweak the Bristlebots to paint how you want them too. :)
Do you have an instructable on how to control the bristle bot?
great sir !!!!
