Cardboard Puppet Stage
Intro: Cardboard Puppet Stage
Here's how you can make a puppet stage in a day.
Its lightweight, strong and portable and looks great for a hand puppet performance.
Includes new tips you can use to make hinge cupboards out of leather and balsa wood / thick cardboard.
Here's how to make the puppets displayed in this instructable: https://www.instructables.com/id/How-to-Design-Hand-Puppets/
Check out more a sample from Eric Guiomar's book step by step
New! Eric Guiomar's new pdf book part 2 is available. Also excerpts of first book How to Make a Ming Table free download here:
Chapter contents
Part A & B French Instructiions for Ming Table
Scroll down to
Check out many French Cartonnistes Websites below:
Check out ways you can use puppetry for educational purposes:
http://www.nostrings.org.uk/
http://www.youtube.com/user/nostringspuppets
Chapter contents
Scroll down to
Extraits du livre
- Table des matières - Fichier PDF (404.5 Ko)
- Tabouret Ming (pages 12 à 15) - Fichier PDF (1.3 Mo)
- Tabouret Ming (pages 22, 23) - Fichier PDF (1.1 Mo)
STEP 1: Measure and Cut
1. Draw the front side by tracing a rectangle onto 2 or 3 ply cardboard.
2. Check the direction of the cardboard, it should be vertical for stronger structure. (If cut on the vertical, it will bend easily)
3. Glue struts to front and back frame. I tried cold glue, but hot glue seems to work best.
STEP 2: Put Up Walls
Trace and measure inner walls and outer walls.
Cut with sharp craft knife, slicing 4-5 times lightly through card, (no energy is necessary).
The gum edges in place with gummed tape.
STEP 3: Make Leather Hinge
1. Cut a small piece of balsa wood or thick card that comes from the back of art sketch books. This will support the fabric hinge. File wood roughly so that the fabric will stick better.
2. Cut and glue a piece of leather to hinge.
Check out my Make Your Own Door Hinges slideshow here for more hinge designs.
STEP 4: Cover the Stage
1. Measure a piece of cloth which is larger than stage.
2. Trim to fit. Use pins if necessary to keep in place while cutting.
3. Use a paper stapler to staple the fabric at the back to hide the staples.
7 Comments
woelfwynde02 3 years ago
Sunny124613 15 years ago
- tip:if you stay with the puppet store for a long time,you sometimes can get discounts,only if it is not a mean old lady,try to get the younger foolish ones to give you puppets at a discount price and usually if you bribe them with like,5 bucks more with the discount price they will let you buy it.
I hope this paragraph helps!!!Sunny124613 15 years ago
caitlinsdad 15 years ago
