Introduction: How to Make a Cat House
This is the instructable that will show you how to make an awesome cat house for your indoor cat.
What you will need for this is a wide variety of stuff so read through this before you start. You will need:
- needle
- thread
- glue
- good sized box (It needs to be like 3 times the size of your cat.)
- felt or other sof fabric you can also use a blanket and you will not need as much felt.
- paper (to make it look nice)
- And string for play
Step 1: Gather the Supplies.
Step 2: The Blanket
For this step you can either make a blanket or use one you found around the house. (make sure it is okay with your parents first.) If you want to make your own measure the box you are making and you can sew or tie your blanket. One more thing you can do is just put some felt or something in their and that will work to.
Step 3: The Pillows
for the pillows I sewed mine and stuffed it with scraps of felt. If you want to you can use an already made pillow. I made a couple to add to the cozyness of it.
Step 4: Prepare the Box
This is an important part of the process. you need to measure your cat and make a door bigger than your cat. If the box has flaps of some sort you must glue/tape them shut.
Step 5: Let Your Cat Enjoy!!!/decorate
If you want to you can decorate the box. If not you can give it to your cant to enjoy.
2 Comments
2 years ago
It's good to see your cat likes it. I once made a cat house and the cat wanted no part of it. :)
Reply 2 years ago
YES!!! cats can be very picky and often they do not want any part of well, anything you make them. What I do is just let them explore the thing I am making and let them get used to it hence the making it on the floor.
