How to Make a Cheap, Portable Magnetic Stirrer
253,452
386
90
Introduction: How to Make a Cheap, Portable Magnetic Stirrer
About: My name is Alex Ngai. I am currently an electrical engineering student at Cornell University. I’m interested in bio-mimetic walking, running, swimming, and flying robots, automation, and 3D bioprinting. Cybo…
I needed a magnetic stirrer to keep some cells agitated for cell culture, but didn't want to spend the thirty or so dollars needed to buy one. This magnetic stirrer uses an old computer fan and some cheap neodymium magnets with a moldable plastic stir bar.
The parts are:
- computer fan
- small magnets: http://www.dealextreme.com/p/super-strong-rare-earth-re-magnets-8mm-20-pack-4248 (free shipping)
- moldable plastic (polymorph, instamorph, shapelock)
- lexan
-batteries
-superglue (cyanoacrylate)
Step 1: Glue the Magnets to the Fan
Prepare and clean the fan for use. Your fan may have two wires (red for positive and black for negative). If it has three wires, the white wire is a tachometer and is not needed. Glue the magnets on opposite sides of the fan head. The magnets in the fan's motor may push the magnets around a bit, so arrange accordingly. I arranged the magnets to have opposite polarities facing up.
Step 2: Add Spacers
The magnets will increase the profile of the fan, so you will need spacers before putting a flat surface on top. The spacers can be anything, I used coins initially. Eventually I snapped off a few pieces of spare plexiglass I had lying around and glued them to the edges of the fan. Either way, make sure the spacers are higher than the profile of the fan with the magnets glued on.
Step 3: Add the Main Platform
I cut a small square of plexiglass over the fan as a platform for any containers I will need to stir. Glue or attach any thin, waterproof material to the spacers.
Step 4: Make the Stir Bar
The stir bar is made of two magnets embedded in the moldable plastic. Simply place the plastic in a container of hot water until it turns clear. Place two magnets (polarities opposite facing) onto the plastic and surround with more of the moldable plastic until the magnets are covered. Then round off the edges and mold until the bar is roughly cylindrical with the embedded disk magnets still inside.
Step 5: Powering Your Magnetic Stirrer
The magnetic stirrer can be powered by any voltage source the fan is rated to. However, make sure your magnets are strong enough to couple together from the fan to the stir bar with the rated speed. If the speed is too high, the stir bar will not spin correctly. I used a 9V battery at first, but used this set of 3 AAA batteries I had lying around. I didn't need torrential currents for mine, so I used a lower voltage. This is a magnetic stirrer, not a blender. The lower voltage will result in a slower fan speed, and the stir bar will better be able to better keep up with the fan speed.
Step 6: Use It
Place any container large enough to allow the magnetic stir bar to fit and start agitating/stirring! Since this unit is so small, you can place it on your desk and use it to stir your cold drinks. I wouldn't recommend hot drinks though, heat will cause the polymorph stir bar to soften and lose shape. If you want an improvement, you can try embedding magnets in ceramic and glazing the stir bar.
Be the First to Share
    • Halloween Contest
      Halloween Contest
    • Fried Food Challenge
    • Fandom Contest
      Fandom Contest
    90 Comments
    pol814
    pol814
    Question 1 year ago on Introduction
    this is awesome, except what is the switch you put the batteries into and connected wires to? It's not in the 'parts' list, and you write as if we all have dozen of those lying around. Some of us don't make our own electronics =P
    mirm1
    mirm1
    Question 3 years ago on Introduction
    dear sir i have an ordinary hot plate and have computer fan pls. tell me how to convert this to hot plate strirrer than you
    mirm1
    mirm1
    Tip 3 years ago on Introduction
    thank you my adress is soha1326@gmail.com dear sir pls. send all this progrrame for me ahmad in iran all detail because i have not any money to buy pls. do this me
    wnaawmr96
    wnaawmr96
    Question 3 years ago on Step 5
    May i know, how many volt the computer fan you used???
    panashem7
    panashem7
    4 years ago
    to improve the magnetic stirrer i think we do not need the fan blades hence to reduce aerodynamic
    friction we can simply cut them off and make our motor to run faster
    since they will be a lesser load.
    denewf
    denewf
    6 years ago
    I guess old age has finally kicked into the grey matter.
    I kinda thought it was the magnets that were the primary factors,
    Not air movement!!!
    cwright15
    cwright15
    Reply 6 years ago
    Did you even read it?
    denewf
    denewf
    Reply 6 years ago
    Read it over several times. As I said, it may be my old brain.
    Still don't see what air movement has to do with a magnetic stirrer.
    Perhaps you might enlighten me?
    borgem
    borgem
    Reply 4 years ago
    While the fan's air-moving function isn't inherent to the stirring, the air movement by the fan may affect the liquid if it is hot and you are trying to keep it that way. The air blowing on the base could potentially cool your liquid somewhat, so if stirring hot liquid is your intent, I would recommend planning your material's design around that potential issue.
    goobyalus
    goobyalus
    Reply 6 years ago
    The fan is just being used as a conveniently shaped, and readily available, motor. The blades aren't important to this.
    shomas
    shomas
    Reply 5 years ago
    "I guess old age has finally kicked into the grey matter. I kinda thought it was the magnets that were the primary factors, Not air movement!!!"
    you were right the first time. Its all about the magnets and nothing to do with air movement.
    For clarity, I'll cover the instructable. It is about re-purposing a throwaway old CPU fan into about the cheapest magnetic stirrer that can be found. There is an elongated piece of plastic covering small magnets inside the glass with the solution to be sired, and is spun by the rotating magnetic field from magnets on top of the fan. In the picture with the glass, it is hard to see as anything more than a white blur at the bottom because it is spinning so fast. But, you can easily see the vortex it generated. The actual fan blades serve no purpose in the stirring process except maybe to keep the rotor from spinning too fast.
    Side note: Like an unbalanced tire will cause increasing vibrations when spun faster, slightly unbalanced magnets glued to the rotor can cause excessive vibrations if spun too fast like say after cutting the fan blades off so that it is no longer loaded by air resistance, the magnets on top may cause excessive vibrations if it spins faster and there the magnets are not balanced.
    Austringer
    Austringer
    9 years ago on Introduction
    Normally, you don't want to use a stir bar with cells since the action of the stir bar and the bottom of the beaker will lyse them. Roller bottles are the common way this sort of thing is done at bench scale.
    Nyxius
    Nyxius
    Reply 6 years ago
    If there are electrolytes in the water you could induce a flow using emf maybe? I don't know if that would kill them or not though. I've done it in a coffee cup. Really cool, but not terribly easy to apply.
    shomas
    shomas
    Reply 5 years ago
    hrm. "If there are electrolytes in the water you could induce a flow using emf"
    I have always seen Magnetohydrodynamics use an emf to generate currents between plates conducted by ions through magnetic field causing a deflection in the ions that pushes the fluid. But, can an alternating magnetic fields induce currents in an electrolyte and those currents induce a reverse magnetic field that opposes the initial change in the magnetic field?
    I guess probably. Important factors would include but may not be limited to:
    1. The rate of change in the magnetic field so either you want really powerful magnets or your magnets have to be moving really fast or both.
    2. Resistance to current flow in the electrolyte.
    or maybe we wont get the the kind of movement we are hoping for. take sodium chloride for example. In water it becomes (Na+) sodium ions and (Cl-) chloride ions. A moving magnetic field would cause + ions to move in one direction while - ions move in the other, in a plane that is transverse to both the magnetic field and the magnetic field's direction of motion. I am moving beyond my area of expertise but overall wouldn't the two momentums cancel leaving little more than a heating effect?
    Nyxius
    Nyxius
    Reply 5 years ago
    You are right about the motion of the ions. However, if we are not picky about the direction of stirring then a pulsed axial magnetic field would alternately push negative ions out and positive ions in, and then when the field collapses reverse directions. If the field also had a rotation whose direction depended on the phase of the pulse, then a toroidal current would be set up. Conservation of angular momentum would create the same vortex pattern of current that the magnetic stir bar creates.
    shomas
    shomas
    Reply 5 years ago
    "However, if we are not picky about the direction of stirring then a pulsed axial magnetic field would alternately push negative ions out and positive ions in, and then when the field collapses reverse directions." This will happen regardless of direction of stirring. During the pass of one magnet with a magnetic field in the axial direction, ion of one type will first be pushed into the center and ions of the other type will be pushed to the outside and return after the magnet has passed.
    "If the field also had a rotation whose direction depended on the phase of the pulse, then a toroidal current would be set up" Some times it seems english is poorly equipped to discus changes in currents and magnetic fields in three dimension of space and one of time, not to mention adding in their interaction on + and - ions so i had a hard time visualizing what you concluded from your statements. But If I may step back for a second and ask "If the ion +- momentums balance, and individually both the + and the - ion to fluid displacement also balanced then aside from induced net alternating electric currents, are we not left with a net 0 fluid current".
    Maybe I should try this on a solution of sodium hydroxide and another solution of sodium chloride to resolve it.
    Nyxius
    Nyxius
    Reply 5 years ago
    Also, one would definitely need to use electro magnets. Probably not possible using solid magnets.
    UygarO1
    UygarO1
    Reply 5 years ago
    This could do.
    bufalloo
    bufalloo
    then that will be my next instructable xD
    tnmann10
    tnmann10
    a cheap multi tier cell roller would be awesome!!!
