Introduction: How to Make a Cheese-Themed Sticker in 5 Minutes
I made this instructable on how to make a cheese sticker because it is extremely easy and fun to make. I used cheese-themed doodles in this 5-minute project, but you can make yours however you want to. You can stick this on your notebook, water bottle, computer, and anything else you can think of!
For this project, I used a sheet of paper, colored pencils, waxed paper, scissors, and clear tape. If you don't have any colored pencils, crayons will be fine.
Step 1: Drawing and Coloring a Picture
In this step, you will draw out the sticker on a piece of paper. The picture can be anything that you want it to be. I drew the outline of a slab of cheese with a black colored pencil and shaded it in with a yellow one.
Step 2: Cut Out the Drawing
After coloring, use scissors to cut out the picture. I prefer to leave a tiny bit of the paper on the edges of your drawing.
Step 3: Lay Down Clear Tape on Wax Paper
By this step, you should have a cut out drawing on your table. For now, push this aside and get a piece of waxed paper that is larger than your picture. Then, cover your piece of waxed paper with transparent tape. Make sure you lay down enough tape to place the drawing in and have about half an inch remaining on all sides.
Step 4: Tape the Drawing Down
You should now get your drawing and place it on top of the waxed paper. Tape your drawing onto the waxed paper. Cover it completely, with no gaps. Keep going, you're almost there!
Step 5: Cut Again
In this last step, you should cut out your drawing with a little extra space on the edges. If you don't, the sticker won't stick on to anything, and will be useless. You should be careful while cutting out your sticker.
Step 6: Completed!
You're finally done making your cheese sticker!
Just peel off the waxed paper and apply it to any surface. You can store it as long as you want, or make sticker sheets with them and gift them.
I had a lot of fun making this, so I made two more. I decided to put these on my water bottle because my computer was already full of stickers. I hope you had a lot of fun making this sticker!
Cheese Challenge
