Introduction: How to Make a Clothespin Gun
In this instructable I will be showing you how to make a precision classroom weapon. It takes a lot of time to create, but if you take your time and make it quality by following my steps, I promise you will be pleased with the results. This will shoot either toothpicks or matches.. this particular model will not shoot the strike anywhere ones but i will soon put up an instructable for one that ignites them when you fire it.
Step 1: Gather Materials
To get started you are going to need to gather some materials that you might have laying around your house.
1) Super Glue
2) Quick Dry Spray (optional)
3) Terrorist Knife =]
4) Wire Cutters (optional)
5) Two Wooden Clothespins
6) A File
7) And Last Of All You Need WAY Too Much Time on Your Hands
1) Super Glue
6) A File
Step 2: Getting Started
Now it is time to get everything ready and disassemble your clothespin. Be sure you keep the metal spring because it is important.
Step 3: Carving Out the Internals
In this step you are going to need your file and your handy little knife. Using your knife, you are going to take out all of the parts like they are shown in the picture. Be sure to take your time and make it nice, because later on when you are finished you will not be able to access this area to fix any problems. You are also going to have to cut off a little bit of both ends of each peg.
Step 4: Glueing
After you have finished your carving you are going to need put the spring back on like shown in the picture and make sure your holes and slit things line up. If they line up you are going to glue the two pieces together and use some of your spray to quicken it up and make it dry stronger. If you want to you can take a piece of another clothespin and attach it to the top to make sure the spring does not pop out of place. This also makes it look cooler also.
Step 5: Sanding
Now you are going to want to take some sand paper or a really fine file and do some sanding to smooth out the edges and blend everything together. This will take a lot of time if you want to make it look nice and professional.
Step 6: Your Done
Now that you are done have fun but be SAFE. Do not fire this at anyone because it might hurt you. You can also make different designs like i did on another instructable on another account. I made it look like an ak 47 and it turned out okay. To fire this you have to push the non red part of the match back into the hole until the spring locks into the notch and then push down on the spring and it will fire.
