Introduction: How to Make a Cutlery Dryer
Hello
I would like to present to you this inexpensive and fast solution for drying cutlery and cooking utensils. Simplistically made with a few nuts and bolts and couple of aluminium cans.
I sourced the nuts and bolts from a local hardware store and the aluminium can were a buy product of a recent bolognaise meal.
If you need a somewhere to dry your cutlery and utensils give this a try!
Step 1: Tools and Materials
For this instruction you need some materials and tools:
5x Nuts and Bolts BZP M3 x 13mm
2x Aluminium Cans
Flat head screwdriver
M3+ Screw or Nail (3-4mm)
Hammer
Marker
Gather the items in the list of items above.
I recommend using a hammer and nail of 3mm to puncture the holes, but, if you don't have a hammer, screw or nail, find a sharp knife to puncture the aluminium can with. Do be safe and careful when doing this.
Step 2: Prepping the Cans
Remove the lid or any wrap surrounding the can and wash thoroughly to remove any glue of food.
Turn the cans over so that the bottom is facing upwards and puncture the can a few times, this will allow moisture to escape.
Step 3: Connecting the Cans
Puncture a hole at the same level on each can near the brim.
Use the nuts and bolts to tightly fasten the two cans together using a screwdriver.
Step 4: Attaching the Dryer to the Rack
If you wish to attach the cans to the rack this is a simple method of doing so.
Use a pen marker to mark above and below the drying rack on the can, as shown in the images, this is to make a puncture hole either side of the rack support to fasten with nuts and bolts.
*This probably isn't the most secure way of doing this so if you can think of a better and more secure way, use your intuitive and do it, and please let me know in the comments.*
15 Comments
7 days ago
And after two weeks, when the cans have gone rusty....what is the next step?
Reply 5 days ago
These cans can't rust. They are aluminium!
Reply 1 day ago
but.... they do! maybe my cans are produced differently?
7 days ago
Great idea; I like how you used those lined cans so they won't rust. Perfect for impromptu situation, like camping!
7 days ago
Great idea - simple and effective. Using two cans adds stability as well as functionality. I'm going to adapt this for use in my workshop. From past rusty experience I'd put a few holes in the base very close to the edge. Water will pool in the 'corners'.
8 days ago
Nice. I'm lazy. I took a binder clip and an empty sour cream container, drilled holes in the sour cream container and clamped it to my metal drain. Works like a charm.
8 days ago
I've done something similar back in the past. I used mine for a paint brush holder back when I did acrylic paintings. That way the bristles would not be damaged. Also I could see which brush I wanted quickly without having to hunt through them.
Tip 8 days ago
Hello, great recycling stuff, I think that water could pour better by drilling holes by the inside to the outside...
8 days ago
I would use the brackets that the satellite or cable TV/Internet people use to hold a cable to the side of your house...I bought plastic ones on Amazon, one Internet guy used similar to bring one cable in, another used aluminum ones. You could pop rivet them to the can after putting them over the wire of the dish drainer or you could screw them to a piece of wood from the inside of the can outward, using the screw that comes with it. Blessings!
8 days ago
Rather than the bolts, you might consider some small screw hooks.
8 days ago
For a stainless utensil holder use an IKEA Ordning holder (4-3/8"D x 5-3/8"H or 4-3/8"D x 7-1/8"H) which have predrilled drying holes on the sides & bottom. When a Brogrund towel hook is bolted to the side (near the top) these are multi-functional i.e. I hang them on my workshop wall for storing tools. These are surprisingly affordable & will last a lifetime.
8 days ago on Step 4
It would make sense and also less work to use zip ties both to connect the cans to each other and to attach them to a dish drainer.
8 days ago
Out of BoX thinker NICE
9 days ago
I like it!
10 days ago
Nice job on this cutlery dryer :)
