Introduction: How to Make a Fortune Teller
Have fun with your own fortune teller
Step 1: Get a Full Sheet of Paper and Place It on a Flat Surface
Step 2: Fold It to the Left and It Should Look Like in the Image
Step 3: And Then Cut Off the Rectangle Part
Step 4: Open the Paper Then Take the Left Corner and Fold It Like a Trangle and Do That to the Rest of the Corners
Step 5: Flip Over the Paper Get the Corner and Make It Like a Trangle and Do the Same to the Other Corners
Step 6: Now Get the Paper and Fold It
Step 7: Then Put Your Fingers Under the Open Sides and Then Lift It Up and Go in Ward
Step 8: Now Put Any Color on the Paper Like in the Image
Step 9: Now Open It and Put Numbers in the Inside and There Suppose to Be 8 Numbers
Step 10: Fold It Again the Same Way
Step 11: Open Like I Said and Then You Could Put Anything Under the Numbers
Step 12: When You Finished You Can Fold It Again and Open It Like I Showed You and Now You Can Play With It
3 Comments
Tip 4 years ago on Step 1
I would not use lined paper. It would work a lot better for you if you use printer paper.
7 years ago
I like your ideas for fortunes that you wrote.
7 years ago
Congrats on your first instructable!
