Introduction: How to Make a French Beret in Tinkercad
Hello! In this project, you will learn how to create a French beret in Tinkercad. If you have TinkerCad experience, this project should only take you 5 minutes maximum. If you are new to the wonders of TinkerCad, this project could take you up to 15 minutes maximum. Enjoy!
Step 1: Making the Hat Base
First, start off with two spheres on the Workplane. Next, stretch one sphere to 60mm in diameter and the other to 50mm in diameter. Also, make the sphere on the right a hole and lower it by 5mm. Then, align both spheres so that the hole is in the center of the blue circle, but slightly sticking out the bottom. Finally, when you group the two shapes, it should start to look like a beret.
Step 2: Adding the Final Touch
Now that the beret base is done, it's time to add the final touch! First, add a cylinder to the Workplane. Next, shrink the cylinder so that it is 1mm in diameter and 10mm in height. Then, rise it and position it to the center of the hat base. Now when you group the shapes, the French beret will be finished! (You may alter the color and size based on your preference).
Fashion Challenge
