How to Make a Gameboy/ Game Controller With a Arduino Leonardo
Intro: How to Make a Gameboy/ Game Controller With a Arduino Leonardo
Hi everyone in this Instuctables we will see how to realize a Gameboy Arduino Leonardo.
In fact it is not really a Gameboy but a disguised joystick.
STEP 1: First : the Hardware
We will need:
- Arduino Leonardo Arduino IDE +
- 8 Pushbutton
- 8 Resistors
- Cables
- Fine wood lamellas and painting (that is more aesthetic)
STEP 2: Step 2 : Decoration !
You are free to do what you want! Unleash your imagination. I preferred to do as below:
STEP 3: Step 3 : Connections
After the paint has dried, you should set the push s buttons and make holes in the wood in order to put the wires and resistors.
The connections are about the same as the image below:
Otherwise, you can modify and in the order you want.
STEP 4: Step 4: the Code
The code operates on the principle of the function Keyboard.write
You can then edit the code and change the keys as you like.
int A=2;
int B=3;
int Up=4;
int Down=5;
int Left=6;
int Right=7;
int Start=8;
int Select=9;
int led=13;
int AState=0;
int BState=0;
int UpState=0;
int DownState=0;
int LeftState=0;
int RightState=0;
int StartState=0;
int SelectState=0;
void setup(){
pinMode(A,INPUT);
pinMode(B,INPUT);
pinMode(Up,INPUT);
pinMode(Down,INPUT);
pinMode(Left,INPUT);
pinMode(Right,INPUT);
pinMode(Start,INPUT);
pinMode(Select,INPUT);
pinMode(led,OUTPUT);
Keyboard.begin();
void loop(){
AState=digitalRead(A);
BState=digitalRead(B);
UpState=digitalRead(Up);
DownState=digitalRead(Down);
LeftState=digitalRead(Left);
RightState=digitalRead(Right);
StartState=digitalRead(Start);
SelectState=digitalRead(Select);
if(AState==HIGH){
Keyboard.write('A');
if(BState==HIGH){
Keyboard.write('B');
if(UpState==HIGH){
Keyboard.write('Z');
if(DownState==HIGH){
Keyboard.write('S');
if(LeftState==HIGH){
Keyboard.write('Q');
if(RightState==HIGH){
Keyboard.write('D');
if(StartState==HIGH){
Keyboard.write('X');
if(SelectState==HIGH){
Keyboard.write('C');
digitalWrite(led,HIGH);
STEP 5: ​Step 5: Transfer and Play!
Transfer the code on the Arduino board and now you can play!
http://youtu.be/rPoRScaPpEY
