How to Make a Grease Bomb
79,323
116
63
Introduction: How to Make a Grease Bomb
About: I've worked for Instructables off and on since 2006 building and documenting just about everything I enjoy doing. I am now the Creative Programs founder and manager for Autodesk and just finished building out…
What are just a few things that come to mind when you think multi day rafting trip? Desolate beaches perhaps? Caveman style technology? Motivated groups of danger seeking risk takers? Excessive amounts of bacon grease? If any of this sounds familiar, chances are you've gone rafting.
One of the biggest pyro displays one can pull off on a river trip is something called a grease bomb. Using a hot fire, a good amount of bacon grease, and some water, the little (or big) pyromaniac in us all can come out and play.
When executed correctly, the simple ingredients hurl a massive fireball skyward, produce squeals of enjoyment from the peanut gallery, and show your group a safe display of what happens when you show complete disregard for that age old saying of "don't pour water on a grease fire".
**Warning this Instructable involves fire, explosions, bacon grease, and danger. If you'd like to do another project involving copious amounts of bacon grease with a much lower danger factor, check out How to Make Bacon Soap. Grease bombs can be very dangerous and should only be done by experienced bacon grease pyrotechnicians. When done correctly they are a real good time.**
Step 1: Gather Grease
The first ingredient to a grease bomb is grease itself. You'll need a good amount of it - around 1 1/2 to 2 cups worth. The more grease you have, the bigger the bomb. Once you've done a small one, you might want to try making a grease bomb that uses more grease - around 3, 4 or more cups of grease ups the anti.
On the river we collect grease from bacon. Trip guests love bacon - so that means that we're usually cooking up POUNDS of the stuff on each trip. Each pound yields about 1/4 to 1/3 of a cup of grease, so collect all the grease you can until you've got about 2 cups worth.
Any fatty meat will produce good grease, so try rendering grease from different sources and see which produces the biggest fireball. (Anyone who can speak to the flammability of different types of animal fats please speak up).
After cooking the bacon, I let the grease cool. Then, I place a coffee filter on top of a non-breakable sealing container and pour the grease through. If your grease has little bits of meat in it, it won't work as well and it will splatter and sputter as you heat it. The coffee filter takes out all of those impurities and results in wonderful amber clear grease.
Step 2: Prep the Burn Area
The first thing on your mind when making a grease bomb should be safety. Because of their explosive nature grease bombs need to be preformed outdoors. Ideally the grease bomb should be set off on a non-flammable surface, such as a sandy beach or large rock. When igniting a grease bomb on a flammable surface such as a front lawn (pictured below) be sure to soak the entire lawn down with a hose before starting your fire.
Think hard about grease bomb placement. Grease bombs produce a giant fireball that rockets towards the sky. You'll need to pick a site that is not only clear of flammable objects around it, but also free of branches and trees above it.
If you have any doubts about your site, think things through, take the time to find the right place, and do things right. Ideally the grease bomb would be set off in the middle of an empty parking lot. Beaches afford the same level of safety and are good candidates. You should be thinking along these lines, not those of - yeah - the courtyard of my apartment building looks like a good place.
In most cases a grease bomb is a fun thing for you and other people to enjoy. That means onlookers - lots of them - so make sure that they are all at a safe distance from the fire (25 feet minimum). If they are too close they'll not only be in harms way, but they'll experience an unfortunate byproduct of a grease bomb - noncombusted grease that rains down from above.
Step 3: Boil Grease in a Can Over a Hot Fire
Before going any further you'll want to run through this quick safety checklist just to be sure that you've met the requirements from the previous step.
  • Is there a fire ban in my area/state?
  • Is there anything flammable around me?
  • Is my burn site non-flammable? And, if not have I hosed my burn site down with water?
  • Is there anything above my fire which could burn (trees awnings etc...)
  • Is the peanut gallery located a safe distance away from the fire so they don't get burned?
Once you've determined that the scene is safe, you are ready to proceed.
You'll want to use a blower, fan, boat pump, hair dryer or billows to make a really hot fire. Regular BBQ coals make great fuel, they just need a little oxygen to reach their full potential. For more extensive coal lighting instructions check out: Best Way to Start BBQ Coals.
Once the fire is burning really well put away the blower, pump or what have you. Next, pour the grease into a suitably sized can for the amount of grease thats been collected and place it right inside the pile of coals. Sometimes the fire is hot enough to heat the grease on the grill itself, but I've found that direct heat from the coals works best.
Heat the grease until it's boiling and watch it closely.
During this time, duct tape a second can onto the end of a long pole or stick. Old boat oars work particularly well - they are about 10 feet long and allow the master of ceremonies (grease igniter) to be at a safe distance from the action.
Finally, build a small barricade using whatever you have around. On the river we use our dry boxes - old WWII boxes that the military used to ship ammunition and generators to the front. You'll want to use this barricade to help hold the oar in place over the fire as well. It also creates a nice hiding spot for the grease igniter to hide behind when the big moment comes.
Step 4: 1, 2, 3 Ignition
Once the grease is boiling in the can it will then go through a few phases.
First it will just bubble a bit. Then, any impurities present in the grease will begin sputtering and spitting small bits of grease out of the can. Chances are, they will fall into the fire below and create small grease fires around the can.
This is a good thing.
Once the fire is burning around the grease can itself, and ideally, on top of the actual grease, it's ready for ignition. (See 5th photo below).
Using the oar cantilevered over the barricade, extend the can of water duck taped onto the end of it and move it into position directly over the can of flaming grease.
Do one more safety check before asking for a count down and then confidently pour the water out of the can on the oar and into the boiling can of grease below. The grease bomb will ignite as soon as the water touches the grease.
Experiment with emptying out different amounts of water onto the grease in order to get different size/multiple fireballs. The more grease you have, the more times you'll able to set the bomb off. Each fireball seems to consumer around 1-2 cups of grease depending on how much water is poured.
Step 5: Extinguish the Fire and Marvel
Once the inner pyro has been satiated, or when you've run out of grease in the can, extinguish the fire with a hose and wet the entire area down again.
This grease bomb was done during June of 2008 in Oregon - a time when thousands of forest fires across the west coast were burning out of control. As a result, we exercised every possible fire safety, stood by with hoses and fire extinguishers (as you may have learned by now, water on a grease fire doesn't work so well), soaked the lawn down before and after we ignited the grease bomb and kept close watch on our proceedings.
At the time, there was a fire ban in California, but not in Oregon, and so we deemed it safe to proceed. If there was a fire ban would not have done this. Forest fires are the real deal and cost not only loads of money, but endanger many lives. Take fire bans seriously and help prevent further fires!
Use good sense when making a grease bomb. Don't hurt yourself, or those around you. Hot fiery grease is fun to look at, but not fun to touch - it will burn you very badly. Do this at your own risk and be safe.
Be the First to Share
    • One Board Contest
      One Board Contest
    • Fix It Speed Challenge
    • New Year, New Skill Student Design Challenge
    63 Comments
    gabe 123
    gabe 123
    2 years ago on Step 5
    extremely dangerous. ill try it
    Logan Hanssen
    Logan Hanssen
    7 years ago
    im going to try this with sap.
    yusaku
    yusaku
    10 years ago on Introduction
    For future refrence wax does that way better get one of those bucket type citronella candle from a hardware store put on fire till its completlymolten/on fire, then put some water in even a spoonful make a notible fireball and a cupful is insane. Use appropriate caustion of course.
    Derek Vigil
    Derek Vigil
    On the picture of the flame it looks like theres a gorrilla on the top right hand corner.
    Screamo
    Screamo
    11 years ago on Introduction
    THANK YOU FOR SHOWING ME THIS! I WILL NOW GO AND INDANGER THE LIVES OF MANY PEOPLE! HAHA ITS ON YOU! > : D
    schwabie
    schwabie
    11 years ago on Step 5
    use bacon soda to help estinguish a grease fire.
    Ranie-K
    Ranie-K
    12 years ago on Introduction
    Here's a WWII poster slightly on topic:
    Ranie-K
    Ranie-K
    Reply 11 years ago on Introduction
    Well, then I have to say Norway, Norway, Norway, I guess. It's also the Norwegian constitution day today, so...
    bombmaker2
    bombmaker2
    Sorry about that. I was thinking while typing and accidently typed that.
    As much fun as this is, do not, I repeat, do NOT do this in your friends garage. Been there and done that. Nothing good will come from it. Well except the garage burning down in an insanely awesome inferno.
     I'd also like to say communism and all who practice it\support it sucks large, black-colored, lolli pops. Of the spoiled variety. Having said that I encourage you all to go forth and BURN THE WORLD DOWN.
    Derin
    Derin
    Rule 1:
    Don't take that to the airport.
    notjustsomeone
    I see that some people have talked about melting wax and it blowing up in their face, but no one seems to have made the connection yet. It's called a wax-water bomb. It's a very similar idea with much more spectacular results. You take a metal bucket and fill it with candles, or just a big 3-wick one, and then stick it in the middle of a campfire. Wait until it starts boiling, it may catch itself on fire, then to make the explosion you dumb a small quantity, like half a dixie cup, right on it, the more forceful the bigger the result. This makes for some cheap camping entertainment. Use extreme caution though, while it's probablly not going to splash on you it can produce a very large fireball. Of course this works best without any wind, and I've seen these make a 50+ foot collum of fire.
    ScienceMMM
    ScienceMMM
    Cool! Can this be mixed with Ammonium Nitrate and encased in a shell?
    PKTraceur
    PKTraceur
    Nice noah! Im assuming Tim Anderson had something to do with this? Are there alterante ways of doing this, other than different fats? -PKT
    noahw
    noahw
    Reply 12 years ago on Introduction
    Nope - this is straight from my involvement in the white water rafting community. An amazing group of DIY problem solvers by their own right, that have absolutely no internet presence or documentation what so ever...well, besides this Instructable of course.
    thematthatter
    thematthatter
    13 years ago on Introduction
    the song that comes to mind is that song by the bloodhound gang, fire water burn
