Introduction: How to Make a Handmade Rainbow 2-Hole Seed Beaded Wide Bracelet for Summer
This Pandahall article is about a detailed tutorial on how to make a handmade rainbow 2-hole seed beaded wide bracelet. Hope you like this handmade rainbow beaded bracelet.
Step 1: Supplies Needed in Making the Handmade Rainbow Beaded Bracelet:
5x3.5x3mm 2-Hole Seed Beads
5x3.5x3mm Green 2-Hole Seed Beads
Clear Seed Beads17x8mm
Platinum Triple Strand Box Clasp
Silver Jump Rings
0.3mm Tiger Tail
Stainless-Steel Scissor
Needle Nose Plier
Step 2: Make the First Part of the Handmade Rainbow Beaded Bracelet
1st, cut a part of 0.3mm tiger tail. Then, thread 2 clear seed beads, a yellow 5x3.5x3mm 2-hole seed bead, 2 clear seed beads, a red 2-hole seed bead, 2 clear seed beads, a white 2-hole seed bead, 2 clear seed beads, a blue 2-hole seed bead, 2 clear seed beads, a green 2-hole seed bead in sequence to the tiger tail. Repeat this step five times. Then, thread 2 seed beads, a yellow 2-hole seed bead, 2 clear seed beads, a red 2-hole seed bead, 2 clear seed beads and a white 2-hole seed bead(as shown in the picture);
2nd, cross the tiger tail through the other hole of the rightmost white 2-hole seed bead (as shown in the picture);
3rd, thread a 2mm clear seed bead and a white 2-hole seed bead. Then, cross the tiger tail through the 2 clear seed beads (as shown in the picture);
4th, cross the tiger tail through the other hole of the red 2-hole seed bead. Then, thread a 2mm clear seed bead and a white 2-hole seed bead (as shown in the picture);
5th, refer to the above steps to add more 2mm clear seed beads and 2-hole seed beads(as shown in the picture).
Step 3: Make the Second Part of the Handmade Rainbow Beaded Bracelet
1st, thread a 2mm clear seed bead and a red 2-hole seed bead. Then, cross the tiger tail through the clear seed bead and the other hole of the red 2-hole seed bead (as shown in the picture);
2nd, thread a 2mm clear seed bead and a white 2-hole seed bead. Then, cross the tiger tail through the clear seed bead and the other hole of the white 2-hole seed bead (as shown in the picture);
3rd, refer to the above steps to add more 2mm clear seed beads and 2-hole seed beads(as shown in the picture);
4th, thread a 2mm clear seed bead and a blue 2-hole seed bead. Then, cross the tiger tail through the other hole of the white 2-hole seed bead and the other hole of the blue 2-hole seed bead (as shown in the picture);
5th, thread a 2mm clear seed bead and a blue 2-hole seed bead. Then, cross the tiger tail through the clear seed bead and the other hole of the white 2-hole seed bead (as shown in the picture);
6th, refer to the above steps to add more 2mm clear seed beads and 2-hole seed beads(as shown in the picture).
Step 4: Make the Rest Part of the Handmade Rainbow Beaded Bracelet
1st, refer to the above steps to add more 2mm clear seed beads and 2-hole seed beads(as shown in the picture);
2nd, connect the two ends of the handmade rainbow beaded bracelet together through 17x8mm platinum triple strand box and silver jump rings.
Step 5: Here Is the Final Look of the Handmade Rainbow Beaded Bracelet.
Do you like this handmade rainbow 2-hole seed beaded bracelet? Wearing this rainbow beaded bracelet during summer, you'll feel cool and vigorous. The key part in making this handmade rainbow beaded bracelet lies in beading the beads. Have a try if you like this rainbow beaded bracelet.
