Introduction: How to Make a Handmade White Pearl Bead Bracelet With Bead Flower Decorated
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Do you love pearl bead bracelets? This article will show you how to make a handmade white pearl bead bracelet with bead flower decorated.
Step 1: Materials and Tools Needed in DIY the White Pearl Bead Bracelet:
10mm White Round Pearl Beads
8mm White Round Pearl Beads
4mm White Round Pearl Beads
3mm White Pearl Beads
4mm White Round Seed Beads
8x6mm White Abacus Jade Glass Beads
3.2mm Golden Round Beads
Golden Star Box Clasps
0.2mm White Fishing Wire
Stainless-Steel Scissor
Step 2: Make the First Part of the White Pearl Bead Bracelet
1st, cut about 400cm 0.2mm white fishing wire and add 4 10mm white round pearl beads to the middle of it (as shown in the picture);
2nd, tighten some knots with the two wires and cut off one wire (as shown in the picture);
3rd, add a 4mm white round pearl bead. Then, cross the wire through the adjacent 10mm white round pearl bead (as shown in the picture);
4th, refer to the above step to add 3 more 4mm white round pearl beads and cross the wire through the 10mm white round pearl beads (as shown in the picture).
Step 3: Make the Second Part of the White Pearl Bead Bracelet
1st, add 4 3mm white pearl beads, an 8x6mm white abacus glass bead and 4 3mm white pearl beads to the wire (as shown in the picture);
2nd, cross the wire through the 4mm white pearl bead, the 10mm white pearl bead and the 4mm white pearl bead (as shown in the picture);
3rd, add 4 3mm white pearl beads (as shown in the picture);
4th, cross the wire through the 8x6mm white abacus glass bead (as shown in the picture);
5th, add 4 3mm white pearl beads and cross the wire through the white pearl beads (as shown in the picture).
Step 4: Make the Third Part of the White Pearl Bead Bracelet
1st, add 6 3mm white pearl beads (as shown in the picture);
2nd, cross the wire through the 4mm white pearl bead. Then, add 3 3mm white pearl beads, a 3.2mm golden round bead and 3 3mm white pearl beads (as shown in the picture);
3rd, cross the wire through the white pearl beads. Then, add 3 3mm white pearl beads, a 3.2mm golden round bead and 3 3mm white pearl beads and cross the wire through the adjacent 4mm white pearl bead (as shown in the picture);
4th, cross the wire through the adjacent 3mm white pearl bead. Then, add 2 4mm white round seed beads (as shown in the picture);
5th, cross the needle through the 3mm white pearl bead and the 2 4mm white round seed beads (as shown in the picture).
Step 5: Make the Fourth Part of the White Pearl Bead Bracelet
1st, add a 4mm white round seed bead and cross the wire through the 3mm white pearl bead and seed bead. Repeat this step 5 times (as shown in the picture);
2nd, add a 3mm white pearl bead and cross the wire through the seed beads (as shown in the picture);
3rd, refer to the above step to add more 3mm white pearl beads. refer to the above steps to make a similar part on the other end (as shown in the picture);
4th, add 3 3.2mm golden round beads (as shown in the picture);
5th, cross the wire through the pearl bead and the golden round beads (as shown in the picture);
6th, add 8 8mm white round pearl beads and 7 golden round beads (as shown in the picture);
Step 6:
7th, add a golden star box clasp through a golden jump ring (as shown in the picture);
8th, refer to the above steps to make a corresponding part on the left side. Then, connect the two ends together (as shown in the picture).
Step 7: ​Here Is the Final Look of the White Pearl Bead Bracelet.
Do you like this white pearl bead bracelet? The middle bead flower embellishes the whole white pearl bead bracelet. Making the middle bead flower may require you some time and patience. Have a try if you like this white pearl bead bracelet.
