Ok your ratios are wrong from a chemistry perspective.
I think this is the chemical reaction you are producing: 48 KNO3 + 5 C12H22O11 = 24 K2CO3 + 24 N2 + 55 H2O + 36 CO2
So the Mr of KNO3 is around 101g and the Mr of C12H22O11 is 342g (3 S.F).
as it is a ratio of 48mol KNO3 : 5mol C12H22O11 you are looking at a ratio of 48*101:5*242 to 2 S.F this is around ratio 49:17 so by doing this you will waist less sugar and it should burn better (less annoying sugar).
Another thing to try is to grind up the sugar and the KNO3 into finer powder. Then compact the powder into a tube. Then make a hole in the center (it will burn faster). This will make awesome 1000m rockets if done correctly.
I have also heard of people caramelizing the sugar to make solid fuel. This could be dangerous but great for rocket making, remember to drill out the center.
To get the rockets to be stable when they fly you need to launch it from a launch rod or something else to guide it. Furthermore it has to leave the rod at ,at least 30 mph other wise the fins will not be able to effectively stabilize the rocket. Also, you should add a nozzle of some kind to the engines to get more thrust. In small engines this is usually done with certain types of ceramic. This will allow the rockets to fly straighter and be less of a hazard to the nearby people.
have been playing with kno3 few years back ago, and this fuel is the most simple rocket fuel you can make from it, but its not perfect, sometimes theres air pocket in it, sometimes it mixes poorly and as you can see in the video bits of it crack of the engine and fly everywhere, however its the best one to start with, you can make it burn much faster by adding red iron oxide and slow it down with some Sodium carbonate, its fun to play with but nothing beats black powder when it comes to home made rocket engines, hope that was useful.
Thanks, ill try the iron oxide as a catalyst. I'm planning to make a water powered grinder for powder, sounds like a good idea to use black powder, But it would be very explosive, better try it then! Cheers.
From eBay for around $7 - $10 per kilo and 10 - 20 for postage. I would recommend not importing it for legal reasons.
X
Autodesk Instructables
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
9 Comments
Raccoon77 8 years ago
Watch October Sky.
benthehen123 8 years ago
Higgs Boson 10 years ago
SAArchived 10 years ago
batonas 10 years ago
mr sethm 10 years ago
