Introduction: How to Make a Kitty Headband in Tinkercad
In this project, I will be teaching you how to make a Kitty headband with Tinkercad.
You will need:
A Tinkercad account (free)
Step 1: Create Your Project
Go to Tinkercad and create a project. Name it based on your preference.
Step 2: Create the Headband Base
Once the project is created, bring out the "ring" shape and enlarge it to about 70mm in diameter. Make it whatever color you would like. Now bring out a box that is in "hole" form and make it overlap an area on the ring (if you want a symmetrical headband, make sure the box is aligned with the headband by using the align tool). Then, group the two shapes, and you should result with an open ring.
Step 3: Adding the Kitty Ears
Bring out two roofs and rotate them so that the triangles on each side are facing up and down. Now make them each 5mm tall and about 29mm wide. Now rotate each triangle so that it fits on the top of the headband base. Then, if you want your headband to be all the same color, use the group tool to group your objects.
Step 4: OPTIONAL: Add Grips to the Headband
If you want your headband to have a little more detail, then you can add grips to it. First, get out the box shape and make 1mm in length and width and 5mm in height. Then rotate the shape 90 degrees forward and copy and paste the box about 5 times. Next, attach them to the top of the headband. Then group all of the shapes.
Congrats! You finished creating this 3D model of a Kitty Headband.
Jewelry Challenge
