Introduction: How to Make Easy Cedar Slice End Tables
In this instructable, I will be showing you how to create these beautiful cedar slice end tables. You can click on the 2 minute video above to see a step by step explanation of the process or keep reading below.
Step 1: Gather Your Supplies
The following is a list of the supplies I used for this project along with a link to provide the specifications:
- Cedar Slices: I found these cedar slices from a local distributor, but you can also find them online.
- Hammer: https://amzn.to/2WyEUdI
- Chisel: https://amzn.to/2FGxsXc
- Workbench: https://amzn.to/2FNjylZ
- Ryobi Sander: https://amzn.to/2JXEz2W
- Sander Sandpaper: https://amzn.to/2HRKxk0
- Table Saw https://amzn.to/2K06lf5
- Minwax Protective Finish: https://amzn.to/2I5PgOi
- Paintbrush: https://amzn.to/2WxwCD0
- Drop Cloth: https://amzn.to/2Uqej5h
- Loctite Power Grab: https://amzn.to/2JUkQAX
- Vase
Step 2: Remove the Bark
Remove the bark from the cedar slices using a hammer and chisel.
Step 3: Sand the Cedar Slices
Sand down one side of the cedar slices until the surface is smooth. Start with a coarse sandpaper with a smaller grit for the heavy sanding and work your way up to a fine sandpaper with a higher grit to get a smooth finish. I also used the coarse sandpaper to smooth down some of the bark that did not come off with the chisel.
Step 4: Remove Any Stumps
If you have a slice that has any stumps from a branch remaining on the edge, you can use a table saw to remove them.
Step 5: Apply a Protective Finish
Use a damp cloth to remove any dust and let the wood dry completely. Once the wood is dry, use a synthetic bristle brush to apply a thin coat of Minwax water-based polycrylic protective finish onto the top and sides of the cedar slices. Make sure to do this step over a plastic drop cloth to ensure that you do not mess up your floor or furniture. Wait at least 2 hours and then apply a second coat. Allow the cedar slices to lay out for 24 hours before attaching them to their bases.
Step 6: Attach the Cedar Slices to Their Bases
For the bases of the tables, I picked out vases that seemed sturdy when turned upside down. You can bring your cedar slices into a store and try them out on some vases to find ones that will work well for you. To attach the cedar slices to the vases, turn the vases upside down, apply Loctite heavy duty power grab all over the bottom of the vases, and press the cedar slices onto the power grab. Then apply heavy books on top of the cedar slices and leave them to harden overnight.
Step 7: Project Completed!
And that's all it takes to make this beautiful painting! If you enjoyed this tutorial, please consider following me on Instructables and subscribing to my Youtube channel to see more content like this. https://www.youtube.com/channel/UCMQQAmEG3HaUyNFH...
Step 8:
First Time Author
6 Comments
3 years ago
They look so cool. Great job!
Reply 3 years ago
Thank you so much! :)
3 years ago
Very unique tables! I love them :)
Reply 3 years ago
3 years ago on Step 7
Very nicely done, Whitney. I especially liked the idea of bringing them into the store to try out bases. --Kink--
Reply 3 years ago
Thanks Kink. Ya I usually bring my projects into stores to find what will go well with them so long as the store is okay with it. Glad you enjoyed it!
