How to Make a Minecraft Ender Dragon Head
Intro: How to Make a Minecraft Ender Dragon Head
MATERIALS
- Large piece of cardboard
- Plywood
- Black paint
- Fairy lights (optional)
- Purple cellophane or Purple paint
- Gold paint or gold pen
- Black pen or sharpie
- Cutting knife
- Jigsaw
STEP 1: CUT 6 SQUARES
With a large piece of cardboard, cut out 25 x 25 cm squares
STEP 2: CUTTING EYES
With one of your previously cut squares, draw some eyes, you can either cut them out and put purple cellophane or keep them drawn on and paint them on later
STEP 3: GLUE THE BOX
Using hot glue, connect your squares into a box
STEP 4: SNOUT
Cut out the 2 images above, make sure that the second image is longer than the first one. This is going to be the snout
STEP 5: EARS
Using cardboard, cut out the image above twice, these will the ears. Make the same shape but much smaller twice, this will be the nose
STEP 6: ATTACH SNOUT AND EARS
With the previously made snout and ears, connect them to the box you made as shown (although not shown, also connect the nose now. you can see faintly the lines on the snout where you connect the nose)
STEP 7: CUT THE PLAQUE (OPTIONAL)
Using a large piece of plywood, cut out a shield shape. We used a finish on it to make it look nice. If you wanted, you can also weather it
STEP 8: PAINT
Using black paint, I painted the entire head, you may have to remove some pieces to paint them properly
STEP 9: CUT a HATCH (optional)
In the back of the dragon cut a hatch, only do this if you planned on putting the lights inside, this will be covered later
STEP 10: INSERT THE CELLOPHANE
If you cut out the eyes, insert some purple cellophane
STEP 11: INSERT LIGHTS (optional)
If you cut out the eyes, insert some fairy lights, or LED's, depending on what you have. I have a small hatch in front of the battery pack so i can access the switch
STEP 12: FINISHING TOUCHES
Cut out a small piece of cardboard, and get your golden pen or paint and paint it completely, then write "Ender Dragon" on it. stick the dragon head on the shield, after that stick your golden plate on it. Now you've finished!
2 Comments
Salman2005 5 years ago
NuclearLemon 5 years ago
