How to Make a Mini Tic Tac Power Bank / TUTORIAL
Intro: How to Make a Mini Tic Tac Power Bank / TUTORIAL
https://www.youtube.com/watch?v=yLVG9OcHP9c&feature=youtu.be
STEP 1: To Do a Mini Tic Tac Power Bank You Need!!!
In today's video I am going to share an awesome idea about how to make a portable charger or a power bank as lots of people call it yourself at home.
We will need only L 7805, a 9 volt krona battery, USB connector and connectors for krona batteries as well.
STEP 2: To Make One Yourself Is Pretty Easy and Simple.
Let's call the DIY craft a mini tic tac power bank because all inside component will be fitted into a tic tac container.
STEP 3: Since a Usual Krona Battery Isn't Enough I Advise You to To Use a Maximum Capacity Krona Battery You Will Only Be Able to Find. Keep Your Fingers Crossed!
STEP 4: I Wish You the Best of Luck!
You can buy voltage regulators on AliExpress. Here is the link to followhttps://goo.gl/0aOl58
3 Comments
Luigi Pizzolito 8 years ago
Don't you need capacitors to stabilize the regulator?
ItsNick 8 years ago
wouldnt the regulator heat up in the case?
Cool!
If the phone drew one amp the voltage regulator would be dissapating 4W:
Pd = (9V - 5V)*1A = 4W
