Introduction: How to Make a Multi-Strand Blue Glass Bead and Seed Bead Necklace
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Do you like DIY multi-strand necklace? If so, this multi-strand blue glass bead and seed bead necklace will be a good choice for you.
Step 1: Supplies Needed in DIY the Multi-strand Blue Glass Bead Necklace:
4mm Blue Bicone Glass Beads
6mm Blue Bicone Glass Beads
2mm White Seed Beads
15x10mm Faceted Drop Glass Beads
Alloy Rhinestone Moon Links
Platinum Bead Tips
1.5mm Silver Aluminum Wire
0.3mm Tiger Tail
0.3mm Silver Copper Wire
Silver Twisted Chain
Silver Headpins
Silver Jump Rings
Silver Lobster Clasp
Stainless-Steel Scissor
Needle Nose Plier
Round Nose Plier
Diagonal Plier
Step 2: Make the First Part of the Multi-strand Blue Glass Bead Necklace
1st, cut a part of 1.5mm silver aluminum wire and twist it(as shown in the picture);
2nd, cut a piece of 0.3mm tiger tail and add a bead tip to the middle of the tiger tail (as shown in the picture);
3rd, add the bead tip to the second loop (from right to left) (as shown in the picture);
4th, hold the two tiger tails together and add a 4mm blue bicone glass bead and 5 seed beads. Repeat this step four times(as shown in the picture);
Step 3:
5th, refer to the above step to add more 4mm blue glass beads and seed beads. Then, add a bead tip to the right end. Then, cut a part of 1.5mm silver aluminum wire and twist it into a corresponding pattern like the 1st step and combine it with the bead tip (as shown in the picture);
Step 4:
6th, refer to the above steps to make the second strand and the third strand (as shown in the picture);
7th, refer to the above steps to make the fourth strand(as shown in the picture).
Step 5: Make the Rest Part of the Multi-strand Blue Glass Bead Necklace
1st, add an alloy rhinestone moon link to the two sides respectively through jump rings (as shown in the picture);
2nd, thread a 15x10mm blue faceted drop glass bead and 4mm blue bicone glass bead to a silver headpin(as shown in the picture);
3rd, add the blue drop bead pattern to the middle blue glass bead through a silver jump ring(as shown in the picture);
Step 6:
4th, cut two equal pieces of silver twisted chain and add them to the two moon links respectively (as shown in the picture);
5th, connect the two ends of the multi-strand blue glass bead and seed bead necklace through a silver lobster clasp and silver jump rings(as shown in the picture).
Step 7: Here Is the Final Look of the Multi-strand Blue Glass Bead and Seed Bead Necklace.
The final look of the multi-strand blue glass bead and seed bead necklace is very stunning, right? As you can see from the above instructions, the making steps are easy to follow. If you like this multi-strand blue glass bead necklace, just give it a try!
