Introduction: How to Make a Pair of Asymmetry Vintage Style Drop Earrings With White Pearl Drop Beads
If you like vintage style earrings, you can try the following asymmetry vintage style drop earrings. Hope you like this pair of asymmetry vintage style drop earrings.
Step 1: Supplies Needed in DIY the Asymmetry Vintage Style Drop Earrings:
Rectangle Retro Style Chandelier Component Links
Antique Silver Rhombus Chandelier Component Links
Alloy Dangle Chandelier Component Links
Tibetan Style Flower Links
4mm White Round Pearl Beads
6mm White Round Pearl Beads
8mm Red Crackle Glass Beads
15x9mm White Drop Pearl Beads
10x6mm White Drop Pearl Beads
Antique Bronze Rhinestone Bead Spacers
Antique Bronze Flower Bead Caps
Silver Earring Hooks
Silver Jump Rings
Silver Eyepins
Silver Headpins
Needle Nose Plier
Round Nose Plier
Step 2: Make the First Vintage Style Drop Earring
1st, add 3 6mm white round pearl beads and 3 antique bronze rhinestone bead spacers to a silver eyepin. Then, add an antique bronze flower bead cap, a 15x9mm white drop pearl bead and an 8mm red crackle glass bead to a silver headpin (as shown in the picture);
2nd, make a loop on the end of the headpin and the eyepin. Then, combine the above bead patterns together (as shown in the picture);
3rd, add the combined bead pattern the middle hole of a rectangle retro style chandelier components link (as shown in the picture);
4th, combine 2 4mm white round pearl beads with a silver eyepin. Repeat this step once. Then, combine an antique bronze flower bead cap and a 10x6mm white drop pearl bead with a silver headpin. Repeat this step once (as shown in the picture);
5th, make a loop on the other end of the silver eyepins and silver headpins. Then, combine a two round pearl bead pattern with a white drop pearl bead pattern. Repeat this step once (as shown in the picture);
6th, add the two pearl bead patterns to the other two holes of the rectangle retro style chandelier components link (as shown in the picture).
Step 3:
7th, add an antique silver rhombus chandelier component link (as shown in the picture);
8th, add a silver earring hook (as shown in the picture).
Step 4: Make the Other Vintage Style Drop Earrings
1st, combine an alloy dangle chandelier component link with a Tibetan style flower link through a silver jump ring (as shown in the picture);
2nd, combine an 8mm red crackle glass bead with a silver eyepin and add it to the Tibetan style flower link. Then, add a silver earring hook (as shown in the picture);
3rd, combine an antique bronze flower bead cap and a 10x6mm white drop pearl bead with a silver headpin. Repeat this step twice (as shown in the picture);
4th, make a loop on the other end of the silver headpins. Then, add the three white drop pearl beads to the three holes of the alloy dangle chandelier component link (as shown in the picture).
Step 5: Now, Let's See the Final Look of the Asymmetry Vintage Style Drop Earrings.
Unlike other symmetrical earrings, the asymmetry vintage style drop earrings are different from each other. Do you like the long vintage style drop earring or the short vintage style drop earring? Just have a nice try if you like the asymmetry vintage style drop earrings.
