How to Make a Pair of Stunning Flower Bead Stud Earrings for Girls
Intro: How to Make a Pair of Stunning Flower Bead Stud Earrings for Girls
Looking for bead stud earrings designs? What about the following flower bead stud earrings? Follow me to see how to make the flower bead stud earrings.
STEP 1: Materials and Tools Needed in DIY the Flower Bead Stud Earrings:
8mm White Round Pearl Beads
4mm White Round Pearl Beads
White Glass Bugle Beads
Silver Ear Studs
20.5x16x9mm Oval Acrylic Links
19x7mm Flower Resin Beads
Yellow Polymer Clay Flower Cabochons
2mm Golden Tube Crimp End Beads
6x4mm Clear Abacus Glass Beads
8x6mm Clear Abacus Glass Beads
9x7mm Wheat Pearl Teardrop Beads
Tibetan Flower Findings
Golden Headpins
Golden Eyepins
Golden Jump Rings
0.3mm Golden Copper Wire
Needle Nose Plier
Round Nose Plier
Stainless-Steel Scissor
Glue Gun
STEP 2: Make the First Part of the Flower Bead Stud Earrings
1st, use glue gun to attach two purple polymer clay flower cabochons onto two golden flower findings one by one. Then, use glue gun to attach a pink 19x7mm flower resin bead onto another golden flower finding (as shown in the picture);
2nd, combine two white glass bugle beads to two golden headpins one by one. Then, add a white glass bugle bead, a 6x4mm clear abacus glass bead and a white glass bugle bead in sequence to a golden headpin. Repeat this step to make another such pattern. Combine 3 9x7mm wheat pearl teardrop beads with 3 golden headpins one by one. Add an 8x6mm clear abacus glass bead and an 8mm white round pearl bead in sequence to a golden eyepin. Then, add an 8x6mm clear abacus glass bead, a 4mm white round pearl bead and a 6x4mm clear abacus glass bead in sequence to a golden eyepin. Repeat this step to make another such bead pattern (as shown in the picture);
3rd, combine the three eyepins with the three wheat pearl teardrop beads (as shown in the picture);
4th, add the bead patterns to the three flower bead(as shown in the picture).
STEP 3: Make the Second Part of the Flower Bead Stud Earrings
1st, cut a piece of 0.3mm golden copper wire. Then, thread a 2mm golden tube crimp end bead to the middle of it and fold the copper wire into half. Hold the two copper wires together and add an 8x6mm clear abacus glass bead (as shown in the picture);
2nd, add the bead pattern to the middle of a golden flower finding by wrapping the copper wires (as shown in the picture);
3rd, add a white glass bugle bead and a 2mm golden tube crimp end bead in sequence. Then, cross the copper wire through the white glass bugle bead and wrap the copper wire (as shown in the picture);
4th, refer to the above steps to add more white glass bugle beads, 2mm golden tube crimp end beads and 2 6x4mm clear abacus glass beads (as shown in the picture).
STEP 4: Make the Rest Part of the Flower Bead Stud Earrings
1st, combine the two purple flower bead patterns and the bead pattern made in Step 2 together through golden jump rings (as shown in the picture);
2nd, add an 8x6mm clear abacus glass bead to the top of the red flower bead pattern (as shown in the picture);
3rd, add the red bead flower bead to the middle of the two purple bead flower patterns (as shown in the picture);
4th, use glue gun to attach a 20.5x16x9mm oval acrylic link onto a golden flower finding and then onto a silver ear stud (as shown in the picture);
5th, add the oval acrylic bead to the top of the bead flower pattern through a golden jump ring (as shown in the picture);
STEP 5: Here Is the Final Look of the Flower Bead Stud Earrings.
This pair of flower bead stud earrings is very stunning and exquisite. There are no professional beading techniques in this DIY project. If you like the flower bead stud earrings, you can collect some beads to make a pair.
