Introduction: How to Make a Paper Plate Bunny
This will give you instructions on how to make a paper plate bunny with just a few materials needed
Step 1: Materials You Will Need
1. White paper plates (If you can’t find these you can paint the plate white)
2. Colored construction paper
3. Glue
4. Markers
5. Scissors
Step 2: Grab a Plate
Grab one paper plate
Step 3: The Nose
Use a brown marker to draw a nose in the center of the plate (noses may differ).
Step 4: The Eyes
Use a gray marker to draw two circles for the eyes. Color in the eyes whatever color you want.
Step 5: The Mouth
Draw the mouth connected to the bottom of the nose in a W shape.
Step 6: Whiskers
Cut six thin pieces of construction paper (any color you want) about four inches long for the whiskers.
Step 7: Whiskers
Apply three dots of glue on both sides of the nose and mouth vertically (up and down)
Step 8: Glueing the Whiskers
Attach the ends of the whiskers to each dot of glue
Step 9: Cut a Plate in Half
Grab another paper plate and cut it in half for the ears
Step 10: Fold a Piece of Paper
Take a sheet of red or pink construction paper and fold it in half hamburger style
Step 11: Cut a Circle Out
Cut about a four inch half circle in the folded part. This will make a whole circle once unfolded.
Step 12: Cut the Circle in Half
Cut the circle you just made out of the construction paper in half.
Step 13: Glue Half Circles to Plate
Glue the half circles you just made to the inside of the half paper plates to finish the ears.
Step 14: Glue the Ears to the Plate
Flip the bunny over so you can’t see the face. Apply glue to the ears then attach the ears with the round side facing in.
Step 15: Allow the Glue to Dry
Let the glue dry for five minutes then your paper plate bunny is done!
10 years ago on Introduction
Pros:
1. Strong visuals that work well with the text
2. Very simple instructions that are easy to follow
3. Good use of the gutters
Cons:
1. The background of the pictures is very distracting at times
2. Some of the steps are repetitive and could be paired with a previous step, like steps 7 and 8
3. Use better titles for your first couple of steps with better action verbs
This project was very easy to follow and I believe that we could construct it easily with this set of instructables.
