How to Make a Personalized Wire Wrap Pearl Flower Bracelet
7,123
150
8
Introduction: How to Make a Personalized Wire Wrap Pearl Flower Bracelet
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Do you love pearl flower bracelet? This article will show you how to make a personalized wire wrap pearl flower bracelet. Wire wrap around bracelets are a great kind of DIY fashion statement jewelry. Most wire wrap bracelets wrap around your wrist four or five times, so they can be pretty long. Today's DIY project is about a wire wrap pearl flower around bracelet. Now, let's see how to make this pearl flower bracelet.
Step 1: Materials and Tools Needed in DIY the Wrap Around Bracelet:
4mm Yellow Pearl Beads
4mm White Pearl Beads
6mm White Pearl Beads
16x8mm Beige Glass Pearl Beads
4mm Green Faceted Beads
Green Drop Beads
1.5mm Golden Aluminum Wire
0.3mm Golden Copper Wire
Round Nose Plier
Diagonal Plier
Stainless-Steel Scissor
Step 2: Make Pearl Bead Flower
1st, cut a piece of 0.3mm golden copper wire. Then, thread a 16x8mm beige glass pearl bead and a 4mm yellow pearl bead in sequence to the middle of the copper wire;
2nd, wrap the right copper wire onto the space between the 16x8mm beige glass pearl bead and the 4mm yellow pearl bead (as shown in the picture);
3rd, repeat the above step five times. In such way, a pearl bead flower comes into being.
Step 3: Twist the Golden Aluminum Wire and Add Two Drop Beads
1st, cut a piece of 1.5mm golden aluminum wire with a length about 45cm. Then, twist the golden aluminum wire (as shown in the picture). Please make sure that the size of middle loop is about the size of your wrist;
2nd, combine the pearl bead flower with the right end of the wrapped aluminum wire through 0.3mm golden copper wire;
3rd, add 2 green drop beads on the two sides of the 16x8mm beige glass pearl bead (as shown in the picture).
Step 4: Add White Pearl Beads and 4mm Green Faceted Beads
1st, cut a piece of 0.3mm golden copper wire and wrap one end of the copper wire onto the golden aluminum wire near the pearl bead flower;
2nd, thread a 4mm white pearl bead and wrap the copper wire onto the golden aluminum wire. Then, repeat this step to add a 4mm green faceted bead, a 6mm white pearl bead and a 4mm green faceted bead in sequence;
3rd, repeat the above step once;
4th, continue to add a 4mm white pearl bead and a 4mm green faceted bead;
5th, refer Step 1 to make another pearl bead flower with 5 4mm white pearl beads surrounding a 4mm green faceted bead. Then, add the pearl bead flower onto the golden aluminum wire through copper wire(as shown in the picture);
6th, continue to add a 6mm white pearl bead, a 4mm green faceted bead, a 4mm white pearl bead, a 4mm green faceted bead, a 4mm white pearl bead, a 4mm green faceted bead and a 6mm white pearl bead in sequence(as shown in the picture);
Step 5: ​Repeat the Above Steps to Add White Pearl Beads and 4mm Green Faceted Beads on the Other Side of the Golden Aluminum Wire.
Step 6: Here Is the Final Look of the Wire Wrap Flower Around Bracelet.
This DIY wrap around bracelet is a popular adornment that fit snugly on the wrist. What's more, unlike bangle bracelet or chain bracelets, this wire wrap pearl flower bracelet do not shift around much. Come on and make one yourself at home.
Be the First to Share
    • Go Big Challenge
      Go Big Challenge
    • Chocolate Challenge
      Chocolate Challenge
    8 Comments
    AkashP18
    AkashP18
    6 years ago
    too good bracelet. i think my gf will dance on seeing it. great job. keep it up.
    Fionna the human
    Fionna the human
    6 years ago
    This is very cool and beautiful. I think I might make it. By the way you are AWSOME!
    DasiyD
    DasiyD
    Reply 6 years ago
    Thanks so much! You also can do it.
    Fionna the human
    Fionna the human
    Reply 6 years ago
    I think i will! Thanks for sharing!
    Simran Sharma
    Simran Sharma
    6 years ago
    wow beautiful bracelet.
    DasiyD
    DasiyD
    Reply 6 years ago
    Thank you! Nice day~
