Introduction: How to Make a Simple But Cool Pop-up Card With Modern Tower
For this project, you will need these materials:
normal paper or Cardstock paper
pencil
Acto knife or scissor
glue
note cards
Label each piece "A" and 'B" respectively make sure they are oriented as shown. :)
Step 1:
TO MAKE A PATTER, hold or tape parchment paper over the template and trace around the edge with a pencil. set the pattern aside. When cutting the pieces by hand, only cut on the black lines then cut along the lines with scissor. The red dashed lines indicate where the paper would be folded, and the blue dashed-dot lines are guides.
Step 2: Label "B"
if you choose a thick cardstock, score by lightly cutting with an X- Acto knife; for a thin cardstock, use a stylus.
cut on the cut lines with an X-Acto knife. keep all lines straight and parallel.
Step 3: Folding
flip over part "B" and insert into part "A" so that bottom tables are in the shown. make all folds along their scores, referring to the photo if necessary. the smaller, square tabs will be glued to the inside of the longer tab it folds closest to.
Step 4: Gluing Pieces Together
begin gluing the tabs ( shown in grey) to the longer flips tat make up the building's sides. repeat for the other three sides. valley- fold up the tabs labeled " A" and "B"
Step 5: POP -UP Card
glue the "A" and "B" flaps to the card base. To set, and allow the glue to dry before opening and closing the Modern Tower
Step 6:
Epilog Challenge 9
Paper Contest 2018
3 Comments
4 years ago
Such a fun and unique card :)
Reply 1 year ago
yes it is that was very KIND of you!โค๏ธ๐งก๐๐๐๐๐ค๐ค
Reply 4 years ago
thank you, Miss Penolopy!
