How to Make a Simple Temperature Control Fan Speed
Intro: How to Make a Simple Temperature Control Fan Speed
STEP 1: Electronic Parts You Need
1 x 10K thermistor
1x IRF540n or n channel MOSFET
1 x 50 kilo-ohms potentiometer
1 x 2.2 uf 16 volts at least capacitor
STEP 2: Connect All Parts As the Image Above
This circuit uses a thermistor as a sensor, the thermistor resistance decrease when a temperature increase.
When the temperature increases the thermistor resistance decrease until the voltage set point that adjusts by potentiometer higher than Vgs threshold, MOSFET change to ON state and make a 12 volts fan start and rotating speed faster when a temperature hotter.
The capacitor that parallels with a thermistor help fan starts instantly at lowest speed when power on, The 12 volts DC fan make noise and not rotating without the capacitor(maybe a cheap Chinese power supply cause it).
I set the threshold point at 25 C, The fan start at lowest speed @ 25 C and rotating fastest @ around 38 C (I touch it and wait few munites to see the result)
Enjoy DIY!!!!
15 Comments
donni1 6 months ago
however much I tune the pot I cannot find the point where holding the
thermistor changes the fan speed, its always the same... any tips/ideas
why please? I used a 10k thermistor, 2.2uF 50v cap; irf540n mosfet; 12v
computer fan; 240v to12v transformer supply...
donni1 6 months ago
janakaheshara 2 years ago
Easy and work project 2 years ago
AttieP 4 years ago
Easy and work project 3 years ago
telefonocastellano 3 years ago
Of course, the performance of the circuit is not as good as expected, the fans starts working at some point (30 seconds from circuit start) or at 45ÂșCelsius of the Thermistor head...
I can't really tell what is triggering the start of the Fans
Skint007 3 years ago
Guile2912 4 years ago
Thanks!
Easy and work project 4 years ago
sum4all 5 years ago
Easy and work project 5 years ago
