Introduction: How to Make a Solar Powered Walkway
However, there is one big fat problem: the sun! When it's dark out, oftentimes the places I'd really like to have a little extra light are just the spots you can't leave a sun jar due to lack of direct exposure to sunlight.
The obvious solution to this dilemma is to separate the solar panel from the sun jar. I extrapolated this a bit further and realized that the only thing you actually need in the jar is the LED, and since you don't have to cram all the other electronics in there, you don't have to stay with the classic sun jar shape.
With this in mind, I combed craigslist for some suitably shaped glass blocks, went to Home Depot for the appropriate solar light, stocked up on speaker wire and came up with the Solar Powered Walkway!
***UPDATE 5/5/10: If you build this project yourself, or something similar, post some pictures and I'll send you a patch!***
****UPDATE 1-1-11
If you are the first person to post a picture of your completed light-up walkway to the comments, I've got a 3 month pro membership to instructables that's all yours!
Step 1: The Walkway
I figured I'd put one of the glass blocks in the path first just to see how it would look during the day. I dug a little hole, just a bit deeper than the end result would be. I poured a little fine gravel into the bottom of the hole, so you wouldn't just be looking at dirt through the glass. I filled it back in around the block, and left the top just a bit higher than the surrounding gravel, as I figured it would settle out a bit. Everyone who saw it thought it looked nice, so it was off to the next step.
Step 2: Solar Power!
I separated the solar panel from the battery/circuit board case and extended the wires that connected them. The panel went on my roof just over the front door (see picture) and the battery case went under my newspaper box, with wires running discreetly along the corners and the edge of the window.
****Edit 1/30/10: It has been brought to my attention that this type of light is no longer available, at least for less than $60 each anyway! Here are a couple of possible alternatives I'm thinking about trying out for the path I'm going to build for my brother:
http://www.dealextreme.com/details.dx/sku.5501
http://www.dealextreme.com/details.dx/sku.7491
http://www.amazon.com/Designers-Edge-L-949-Rechargeable-Solar/dp/B0013HPNRY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1264605147&sr=8-1-fkmr0
***Update 4/26/10 -- User Candor has pointed out this alternative to the lights I used, looks like it might be a good one:
http://www.ikea.com/us/en/catalog/products/70177439
***Update 3/2/11 -- IMPORTANT -- Looks like the IKEA link above is dead, here's a new option from their website:
http://www.ikea.com/us/en/catalog/products/70200939
Also, I did a quick amazon search that revealed some possible good options for this project.
I just want to say that I don't recommend the dealextreme lights for the walkway project, they were a bit dimmer than I would like for this. They worked out well for the bottle lights instructable I did, but I don't think they'd be so good for this one.
7/30/12 -- IMPORTANT UPDATE
I don't recommend ANY of the christmas light options for this, they are all too dim. All of the other links above are dead or useless . . .
*** Update 5/8/13 -- Thanks to Liv Laster and wickedq for some more suggestions for solar lights!
http://www.reusablerevolution.com/
http://www.rakuten.com/prod/solar-powered-outdoor-beach-pool-and-patio-umbrella-led-light/246976804.html?listingId=264737107
http://www.northerntool.com/shop/tools/product_200514205_200514205 <--- I particularly like this one
http://www.kmart.com/smart-solar-san-rafael-solar-string-light-20/p-07129475000P?prdNo=43&blockNo=43&blockType=G43
http://www.walmart.com/ip/Smart-Solar-Solar-30-Piece-Crystal-Ball-Light-String/21397504?findingMethod=rr
Step 3: Get to Work!
Crack open the solar lights and separate the panel from the body. There are three wires that connect them, so measure the distance from where you'll be mounting the panel to where the body will be mounted, and then add several inches. Extend the three wires by that amount.
Within the body of the light, unsolder the LEDs and replace them with about 6-10 inches of speaker wire. Make sure to seal everything up well with epoxy or silicone! Mount this whole assembly on your house first, make sure it works, then prepare your glass blocks. I used epoxy (because I'm an idiot) to mount the panel to the roof and the body under the paper box, and then stapled the wires in place.
At the corner of each of your blocks, mount an LED of your chosen color, tack it in place with hot glue, then cover the whole shebang in epoxy or silicone. Make sure you leave the leads exposed!
Update 8-3-14: It's been mentioned in the comments that speaker wire isn't really meant for outdoor use--you may want to upgrade to something heavier or use some conduit. Also, silicone might not be the best option for sealing these, as it reacts with solder and copper and could cause problems down the line.
Step 4: Get to More Work!
Cut speaker wire to these lengths. Make sure you label them for easy installation later. Strip the ends of the wires and solder up one end to each of the bricks. After these are attached, epoxy or silicone any exposed wire or solder.
As described in step one, dig the holes in the path, fill the bottom with gravel, and install your blocks. In addition, you'll need to dig out a little trench between each block, to run your wires through. For this reason, I started with the one that was farthest from the solar light, accumulating more wires in the trench with each brick I added.
Eventually I ended up at the solar light and soldered each of the block wires to one of the loose wires installed where the LEDs used to be in the solar light. Let me tell you, soldering outdoors in the dark is a little bit trickier than doing it at the workbench! Make sure you coat all your exposed wires in epoxy or silicone to keep the rain out.
When you're done, bury all the wires, flip the switch, and enjoy your Solar Powered Walkway!
Step 5: Final Thoughts
This was one of the first electronics projects I did after we bought our new house last spring. I'd been moving and unpacking and fixing up little things for a month and a half and was just sick of neglecting my more eccentric hobbies, so this was a nice entry back into doing strange things with multicolored lights. I haven't posted it until now because I had other projects going, and then somewhere during the month of October while I was busy making my proton pack extra awesome, a big wind storm came through and knocked the solar light out from under the newspaper box, banging it up a bit. It's still attached, but the lights don't work all the time. I finally rigged up some battery power for the lights so I could take some decent pictures of the path. My plan is to either repair it or replace it with one of the other ones I picked up. I hope I can repair it, as I'd like to add more lights around the yard once I've done more with the landscaping.
As always, thank you for looking! Please take the time to leave a rating and a comment, they are always appreciated. I would also love to see pictures if you decide to make something like this yourself. If you post your pictures in the comments section, I'll send you a DIY patch!
****UPDATE 1-1-11
