Introduction: How to Make a Tied Fleece No Sew Blanket
Here are the steps in making a very simple fleece blanket with tied ends. No sewing required! You will need 2 pieces of fleece, about 1 to 1 1/4 yards each, a pair of fabric scissors (or a rotary cutter - much easier!), cutting board (or some kind of cutting surface) and a ruler or straight-edge.
Step 1:
Lay the two pieces of fleece wrong sides together.
Step 2:
With the fabric on top of each other, trim off any ends as necessary to make them the same size.
Step 3:
Use a rotary cutter and cut right along the edge of your ruler or straight-edge.
Step 4:
Cut out a square about 3-4 inches from each corner. This will prevent bunching of the material in the corners and help to make tying easier.
Step 5:
Make sure you cut out the square from all 4 corners of the fabric.
Step 6:
Next cut out slits - almost like a fringe - about 3 inches deep all the way around the fabric. Just make sure you cut deep enough so that you can tie the pieces together. If the slits are too short, you won't be able to double knot them.
Step 7:
This picture shows that you cut the slits through both pieces of fabric while they are layered together. This way, you have the same number of slits all the way around.
Step 8:
Tie the matching top and bottom slits together into double knots (helps them to say together after washing).
Step 9:
Continue tying all the way around the fabric until your blanket is complete!
Step 10:
Fold the blanket and wrap with a ribbon (or even a piece of the fabric that you trimmed off). Add a book and give as a gift. Our local Moms in Motion group (go MIMs!) donates these books and blankets to inner city school children through a program called Buddies, Bridges & Brains based in Victor, NY.
9 People Made This Project!
- Sweetbee7 made it!
- Akgirl__ made it!
- plainspiper made it!
- ShanaB0519 made it!
- AyeBreeJ made it!
- NicoleB210 made it!
- VikkiR8 made it!
- baptistdiva made it!
- LouiseS21 made it!
78 Comments
Question 4 years ago on Introduction
Is it ok to use peaking sheets to cut fabric?
Answer 4 months ago
For most fabrics yes. I wouldn't recommend it for this product because you have to tie it together and it may not come out how you would like. You can use Anti-pill fleece and that helps a lot. The use of pinking sheers is so the fabric won't fall apart at the edges. So if you use an anti-pill fabric pinking sheers won't be needed.
Answer 3 years ago
I would try a mini blanket and wash several times with heavy clothing to see if it frays. Pinking shears might just lose mire fabric with laundering?
Answer 4 years ago
Do you mean pinking shears, the shears that end up with a z edge rather than a straight edge? Probably not a good idea, IMNSHO.
Question 2 years ago on Introduction
I' m wanting to make a couple queen sized tie blankets. Gas anyone ever made one and how much material did you need?
Answer 4 months ago
Measure how long you want your blanket to be. For every 3 feet that is a yard. So if you want your blanket to hang off the sides, also plan for that. Personally, I am with a person who is 6 feet. That means I need 2 yards of the fabric. I also want room for the cuts and for moving around so I bumped it up to 3 yards just to be safe. Hope this helps!
Question 4 months ago on Step 6
How “wide” do you cut the strips??
Question 1 year ago
At what point do you turn the fabric right side in? The beginning instructs is to have wrong side of fabric showing
Answer 1 year ago
It says to have the wrong sides together so there’s no turning inside out.
Reply 1 year ago
Thank you
Tip 1 year ago on Step 6
I had to cut mine in about 4 inch strip because when I tied it, there was barely any “fringe” The directions were super easy to follow! Thanks!!
Question 1 year ago on Step 1
So when u put them the wrong way when do u flip them around
1 year ago on Introduction
Thank you for posting this!! It was so clear and simple. My 5th grade Girl Scouts were able to easily follow the instructions.
Question 3 years ago on Step 1
Why do u need to put wrong sides together?
Answer 3 years ago
So the graphic you want to show will be on the outside of the blanket.
5 years ago
This was a great refresher tutorial but the step of tying only three sides then flipping the blanket right side out was skipped.
Reply 3 years ago
You would lose the pretty fringe if flipped, and it won’t lay as flat.
Reply 5 years ago
Actually the fabric is not inside out so there’s no reason to flip them.
Question 4 years ago on Step 2
How much material will it take to make a blanket for a baby bed?
Answer 3 years ago
Measure the bed. Remember if you made it larger, it could advance with the child into a toddler bed!
