Introduction: How to Make a Water π¦ Throwing Alarm
First Gather all the components needed for this
1. Relay
2. IN4007 Diode
3. Any NPN transistor
4. Water pump
5. Lm358 Microphone module with high output
6. micro Usb Female jack
7. Wire
8. 3mm heat shrink tube
9. Waste bottle /container
10. Waste cardboard
11. Relay Module (optional)
Step 1: Make the Circuit
You can refer to this image for making the circuit connections are quite easy
Step 2: Rearrange the Connections
Once your circuit is completed cut the pumps wire and make two holes in the waste bottle/container put the pump inside the bottle then make the wire and the pipe come out from the bottle/container
Step 3: Glue the Components and Make a Base
Here take an old cardboard price and then on that glue your components, I would recommend you to use Hot glue
Step 4: Tune Your Product
Raise your phone's volume and I would recommend you to keep it at full
There is a blue potentiometer on the sensor ,I would recommend you to tune it at max efficiency , though it will consume around 2-3 more Ma but it is worth it
Step 5: Succes!
You did it , you built your own water throwing alarm just fill the bottle/container with water , place your phone on cardboard and wait for the alarm
https://youtu.be/_HVhaJDmfzk
You can checkout my youtube video on this to view the full testing
Thanks!
Water Speed Challenge
