How to Make a Wrench on Auto Desk Inventor
Intro: How to Make a Wrench on Auto Desk Inventor
A complete wrench made in Auto Desk Inventor. It represents the abilities one may need in their future and the possibilities of 3D printing.
STEP 1: Create a Baseline
Step 1) Set up a straight line from the origin and make it 240 mm. From there make circle and the circle at the origin.
STEP 2: Create the Top of the Wrench
Step 2) Change the width (using dimension) and make it 25 mm, make the height 27.5mm.
STEP 3: Create the Jaw of the Wrench
Step 3) Make a line in cutting through the top portion of the circle and mirror. Secondly, create an arc which connects the two lines. Lastly, use the trim option to cut off top of the circle to make the front of the wrench.
STEP 4: Create the Profile for the Wrench
Step 4) Using the circle button create a circle around 250mm away. Next, go to circle and in the middle, create 2 six sided polygon and make them opposite to each other. Make the circle 33mm and make the polygons both 25mm. Lastly, use the mirror option to make the line connecting the side to match and use the trim option to cut off all necessary parts.
STEP 5: Make the Wrench 3D
Step 5) Use the Extrude option make both sides 10mm and the shaft 6mm (use the center option to even everything).
STEP 6: Fillet the Incepting Parts of the Wrench
Step 6) Use the Fillet option to fillet the sections which connect to each other with and make the connection 30mm.
STEP 7: Change the Materials
Step 7) Go to the materials buttons and click the chrome polished option, and there, you have a wrench.
