How to Make a Writing Quill
26,315
381
35
Introduction: How to Make a Writing Quill
About: I have no idea what I'm doing.
For more than a thousand years, the feather quill was the dominant writing utensil of the Western world. There are many artists, prop-makers, and enthusiasts today who still use quills and have learned to create their own. The process isn't difficult; it does, however, require a bit of practice to produce an instrument that will allow you to write efficiently and without blotting your page with ink.
I would recommend creating several quills at a time to both take advantage of the extended time required for some steps, and to allow yourself to try the steps several times over.
For this project, you'll need:
-several feathers, 8"+ in length
-fine sand
-an empty tin can
-a conventional oven
-scissors
-an Xacto knife, or other sharp knife
-ink
Step 1: Choosing a Feather
When looking for feathers for your quill, keep a few things in mind. Firstly, your ideal feather has a shaft of around a quarter of an inch thick, or more. A smaller diameter will make the writing instrument more difficult to hold. Look for feathers that have a good length of calamus, the translucent tube at the writing end of the quill. A longer calamus means that you will be able to resharpen and continue to use your quill for some time without running out of feather. In some feathers, particularly those bought in hobby shops, the calamus can be crushed by the packaging or cleaning process; these feathers can't be used as quills. When shopping around for feathers, try to select packages with as few crushed feathers as you can.
I chose plain, white turkey feathers for my project. They came three in a bag for about a dollar at Michael's.
Step 2: Preparing Your Quill Before Tempering
Before you temper your quill's writing shaft (more on that in just a moment), consider prepping the feather into a more pleasing and useful shape.
The first image here is of the three quills I made in this run before I shaped them for the most part. You can see that one of them has already been shaped and used for writing without tempering it first. The untempered quill didn't perform nearly as well as the tempered quills, and it's a step I won't skip again.
In the second image, we have (from left to right):
1) The "afterfeathers" removed and part of the vane stripped away to begin higher on the feather. They can be plucked away for the most part, though I did utilize my Xacto knife. The purpose here is to get much of the feather out of the way of your hand when writing.
2) The flaky scaling on the calamus and the remnants of the barbs have been sanded away; I used a medium-fine sandpaper, though the back of your knife works fairly well. This cleans up the outside of the shaft and makes shaping it easier later on.
3. The vanes of the last feather have been trimmed away to shape the overall look of the pen. This final step is purely aesthetic. Though it was common to remove most of the vane for practicality's sake, your quill can ultimately look however you wish it.
Step 3: Acquiring Sand for Tempering
To temper the quill, you will need some fine grain sand, a tin can to contain it, and an oven in which to heat it. You have several options here, the easiest of which is to buy sand at the hobby shop when you purchase your feathers. However, if you've already made your trip to the store, or are attempting to spend as little money as possible on this project, there's another answer. If you have a sandy pit or play area nearby and already own a sifter, you always have the option to go sift your own sand. I chose to do this, and I do have some tips for the process.
1) Firstly, begin your quest with the knowledge that you are about to render your sifter useless for kitchen prep. I imagine that with persistence, you would be able to remove most if not all of the sand from the sifter. That's not a chance I'm going to take, especially as I don't use the thing that often anyway.
2) Take your empty tin can with you to wherever it is you're gathering sand. It provides both a means of carrying and measuring the sand; why sift more than you need?
3) When choosing a patch of sand to scoop from, try not to dig too deep; the moister the sand, the more difficult the sifting will be. (In addition, because we had gotten some rain in our area as I was tackling this project, I ended up having to bake my sand in the oven to dry it out quickly. It was as simple as spreading it out on parchment paper on a baking sheet and putting it in the oven until it had preheated to the required temperature. I then sifted it another time or two to remove the larger particles that had slipped through. If you use this method, be aware that your sand will be very hot! Use caution when handling it.)
4) If you have a crank sifter, do not use the crank or turning mechanism in your sifter. As tempting as it may be, it doesn't make the job any easier; it only succeeds in jamming up with sand. Far easier was simply scooping up sand with it and shaking it over my tin can until the can was full. Don't forget to dump out the large particles between scoops!
Step 4: Tempering the Shaft
Now that your feathers are prepped and you have your sand, it's time to learn about tempering. Tempering a quill refers to using heat, typically in the form of hot sand, to increase the strength and brittleness of the shaft by removing moisture from it. The nib that you carve from a tempered shaft will deform much less quickly than an untempered nib.
To temper your feather, begin by putting your tin can of sand in the oven at 350 degrees Fahrenheit for 15-20 minutes. I set mine on top of the baking sheet and parchment paper I had previously used for baking the residual moisture out of my sand. When your sand is ready to come out of the oven, you can stick the shafts of your prepared feathers as far into the sand as they will fit. Here they will stay until the sand cools to a safe temperature.
In my experience, it took about an hour and a half for this step. Because of the extended time taken here, I prefer to temper three or four quills at a time. You should be able to see a clear difference between the coloration of a tempered and an untempered calamus. While I don't have a picture of the latter, you can see that the tempered shaft is more opaque than before, and it will bend less in the hand.
A variation upon this tempering process involves soaking the feather for a day before placing it in hot sand. I haven't personally tried this, but I've heard that it allows the shaft to maintain some of its flexibility while still improving its tolerance to wear.
Step 5: Shaping the Nib
Using an Xacto knife (or similar, VERY sharp blade), slice the end of the shaft at a 45 degree angle on the "underside" of the pen as it would sit in your hand. There will be more shaping to be done, but for now, you've opened up the inside of the calamus for cleaning. Using a thin tool such as a toothpick, clean out the matter from the inside of the shaft. This will help prevent gobs of ink from getting caught in the membranes inside the pen. Be gentle with the shaft at this time; it doesn't take much force to split the calamus in places you didn't intend.
After the membranes have been cleaned out, you're ready to start shaping the nib. I have found the best way to do this is to observe fountain pen nibs and try to emulate their design. Depending on what you wish to use the quill for, you may desire a wider nib or a narrow one. Experiment with different shapes and find the one that suits you.
Begin by "slitting" your ink reservoir into the end of the pen. To do this, lay the shaft with it's "underside" (the opening created when you cut it at an angle) facing upwards. Using the tip of your knife, press into the middle of the shaft until it splits down the center to the tip of the nib. Once your reservoir has been cut, you're ready to move forward.
The third picture is of the shape I typically aim for when I cut nibs; using the reservoir slit as my center line, I aim to make the nib symmetrical. The primary goal is to provide a narrow writing point, although there are characteristics which make some shapes more useful than others. By slicing in again and narrowing the tip, you encourage the ink to stay in the top of the pen instead of pooling at the writing point. This is possible because of the surface tension of ink; it has a tendency to remain in the curved tube of the shaft rather than on the flat underside of the nib.
UPDATE 4-30: I added a couple of pictures to try and give you a better idea of the shape of the nib. This is several sharpenings later; you can see the pen has been used for writing and subsequently cleaned out.
Step 6: Bonus Step: Boosting Your Reservoir
A trick of the trade used as a means for extending your charge of ink, some quill makers will take a barb or two from their feather and insert it into the end of their quill. This small bit of feather allows the quill to hold a greater charge of ink, allowing you to go longer without dipping your pen. While not necessary, I've found this greatly increases the amount of writing I can do on a single dip.
1. Begin by selecting a barb of around an inch in length
2. Make a 'U' shape out of the barb; it will probably crease or bend in the middle, and this is okay.
3. Poke the loop, open side first, into the end of the quill, lining it up with the ink reservoir. One "leg" of the u-shaped barb should be laying along the slit of the reservoir. Using a tool like a toothpick, prod the barb further into the calamus so that the ink collected in the barb doesn't drag against the paper while you write.
I typically replace this small loop every time I clean out my pen for simplicity's sake. It can be recovered during the cleaning, but as I have an entire vane full of replacements, I don't worry too much about it.
Step 7: That's All She Wrote
And there it is! You've made a quill! All that's left is to dip it in some ink and take it for a spin.
Some final notes on using your new quill:
  • I get more use out of my own quills when I clean them after using them; allowing the ink to build up keeps you from getting a good charge. To clean India ink out of a quill, I just run it under the tap and use my fingers to clean the outside. To get the ink on the inside, I trim away half of the cotton on a Q-tip and moisten it before swabbing the inside of the shaft with it. If you have a shaft larger in diameter, you may not need to trim the Q-tip, but mine are typically narrow enough that doing so would likely crack the shaft.
  • Is your quill getting dull? No worries! Just sharpen it like you did when you first cut it!
  • If you remember how to write in cursive, I would highly recommend it, as it was developed for a time when we wrote with quills. Because you pick the pen up from the paper less often, you'll find that less ink is wasted when you write in cursive. In addition, the smoother movement will cause less ink to be splattered on the page.
  • You will probably get ink everywhere. Just a head's up.
  • Don't want to go buy ink from a hobby shop? No worries; you can make your own. All you need is charcoal powder/dust and a little bit of rubbing alcohol. Mix well and write to your heart's content.
Be the First to Share
    • Retro Tech Challenge
    • Robots Contest
      Robots Contest
    • Halloween Contest
      Halloween Contest
    35 Comments
    acoleman3
    acoleman3
    6 years ago on Introduction
    interesting ible, but i have to say tempering quills you buy from the shop is a waste of time. the only ones that need to be tempered are fresh from the bird when the shaft is still too soft to use. an air dried shaft is very suitable to write with. another thing is a better source of quills is here:
    http://www.smileyme.com/feathers-turkey-quill-feat....
    she sells both right or left wing feathers by the pound for about $50. that's over 200 feathers which is pennies compared to michael's art supply. (note: if you're right handed, use left wing quills so the shaft won't poke you in the eye. believe me, it's not fun)
    something else you never went over is a quill point can go a few days between cuts, even with heavy use. a week with a pointed nib. the primary problem you're going to run into, especially with a pointed nib, is it absorbing ink and becoming too soft to write with before it blunts. i have a pen stand with 9 pens in a row, starting with the first pen. i write mostly using the littera bastarda, textura quadrata and textura prescisus vel sine pedibus hands so i cut my nib with a 1-2 mm chisel. when my letters start getting all wonky and the ink isn't flowing like it should, i put the pen back, grab the next in line and continue writing until i get to the last quill, whereupon i go back to the first one which is now dry and hard again. with that method, it's about two or three days before i have to actually sharpen them.
    StJost
    StJost
    Reply 6 years ago on Introduction
    I'll have to keep that in mind about not needing to temper storebought feathers!
    I would be very interested to see pictures of your pen nibs, if you care to share them. As you surely can tell, I'm not very experienced with making quills; I'd love the opportunity to see the steps you take when you carve yours!
    acoleman3
    acoleman3
    okay, i pulled out one of my wild turkey feathers so it's easier to see. by paring down the sides further, it could easily become a pointed pen.
    acoleman3
    acoleman3
    huhh.....yeah i'll have to upload one or two later today.
    JohnGrey
    JohnGrey
    8 months ago
    Thank you so much. Very relevant information. I am glad that I can use your advice while entering university. This is a very important skill for me. I am currently studying English and am actively practicing writing articles. It's a pity that I don't use a pen. I'll even tell you that in general only essayassist review can be used. This service will be relevant to readers. Have a nice day and good luck in the writing.
    antagonizer
    antagonizer
    Wow, I was just thinking about putting out this same exact instructable. Looks like you beat me to it, and did a great job at that. If you're looking for something more decorative, you can often score turkey feathers from your local abattoir. I, personally appropriate a few wing and tails every year from local road kill.
    HollyHarken
    HollyHarken
    Very interesting! I would like more detail on how to make the loop to hold more ink. It would also be helpful to know how to clean the quill after using it. You don't give details on how to do that. It is fascinating to me to learn a lost art.
    StJost
    StJost
    As per your request, I've added a few more pictures on inserting the barb into the shaft that will hopefully make it a little clearer than it was. As far as cleaning goes, I've found it's actually very easy to just use Q-tips and regular tap water to clean the nib out (at least when using India ink). Just make sure the Q-tip does in fact fit in your shaft without forcing, or you may risk cracking the pen!
    acoleman3
    acoleman3
    a recipe for iron gall ink:
    200 ml Red wine (merlot or cabernet sauvignon works great)
    31 g Oak Apples (grind them first in a mortar) - product 37400
    16 g Iron(II)Sulphate - product 64200
    19 g Gum arabic powder - product 63330
    dissolve the gum arabic overnight in half the wine.
    break up the galls and grind them into a small powder and measure out 31 g (a coffee grinder set to espresso works great for the grinding if the pieces are coffee bean size or smaller. don't worry, it's not toxic nor does any residue affect the taste of any coffee ground after it's cleaned up).
    in a stainless steel bowl (one you do NOT cook in), heat the 100 ml of straight wine on a slow heat, just to the point where it starts producing steam. if it begins to seethe, it's too hot.
    add the 100 ml wine/gum arabic, powdered galls, iron sulfate and stir for about 30 seconds, then take off of the heat.
    stir well and decant into an airtight bottle, let it sit for a couple/three days to gain potency and then strain into another air tight bottle (don't use your good tea strainer and funnel for this. some fluffed up cotton wool and a cheap funnel are perfect).
    it may not be easy to see at first when you write with it, so another idea is to add 15 ml worth of logwood dye (which you can get from amazon on the cheap) and add that before you stir it while it's still on the stove.
    when sludge starts forming in the bottom of the ink, strain it and add 5-10 ml of rice vinegar to refresh its acidity.
    for amusement's sake, here's the traditional recipe (with traditional spelling):
    “Take a quarter strong wine, put it into a new pot, and set it on a soft fire till it to be hote, but let it not seeth, then put into it foure ounces of gauls, two ounces and a half of gum Arabike and two ounces of victrall, al beaten into small pouder, and shifted through a sieve, stirre it with a woden stick, and it will be a good inke.”
    Hopesurfer
    Hopesurfer
    6 years ago
    How do you rid your fingers of ink?
    Thank you.
    KateGladstone
    KateGladstone
    Almost any ink will come off easily if you rub the skin with Nair, Neet, or other liquid hair-remover for 10-30 seconds, then scrub with soap and water, towel dry, and repeat once if there are still any traces of ink. Doing this for the stated time will NOT be long enough to remove hair.
    I am a calligrapher, fountain pen collector, and handwriting teacher, who often needs this trick.
    acoleman3
    acoleman3
    haha, i write with iron gall ink and end up with scribe's fingers for quite a few days after.
    StJost
    StJost
    For me, the India ink came off with no problem when I took a shower, so I would imagine any washing with soap will take it off. It may require more scrubbing if you're in a hurry. If that doesn't work for you, consider trying rubbing alcohol to remove it. Just moisten a paper towel with the alcohol and wipe the area until clean.
    WVSundown
    WVSundown
    Excellent Ible! I've noticed some mechanical quill pens have a hole above the nib split. I always thought it was to help capture more ink, but after seeing your quills, I now wonder if a small hole would prevent the nib cut from splitting further up the calamus.
    StJost
    StJost
    I too have seen this. I tried to replicate it in one of my quills, but I didn't notice a difference in the charge that the quill held, so I would have to guess that it does have something to do with keeping the reservoir at the appropriate length. I would encourage you to experiment with this!
    WVSundown
    WVSundown
    Thanks for your response. If I ever get around to making a quill again, I may try drilling a small hole before splitting the nib and see what happens.
    acoleman3
    acoleman3
    i've used both with and without the hole and found no difference.
    asteidl
    asteidl
    6 years ago on Step 5
    Great use of shadow in the last photo. Good work.
    grannyjones
    grannyjones
    I wonder if many good feathers are shed by the non-migratory Canada geese that seem to be everywhere these days.
